Thread: correct spark plugs/wire set
Results 1 to 5 of 5
  1. #1 correct spark plugs/wire set
    Dec 2011
    MN
    are these the correct spark plugs for 2001 pontiac grandprix 3.8 NA?
    Autolite Xtreme Performance XP606 - Spark Plug | O'Reilly Auto Parts
    are these the correct spark plug wire set?
    OmniSpark 9603 - Ignition Wire Set | O'Reilly Auto Parts
    thinking about picking this up too to get the old boots off
    Lisle 51750 - Wire Puller | O'Reilly Auto Parts
    thanks for the help
  2. #2 Re: correct spark plugs/wire set
    Portland Oregon
    Looks like the right wire set. If you're going to spend 7 dollars a plug, I would just get factory ACDelco's. I believe Oreilly's can order them or you can get them at the dealer as they probably have them in stock.
  3. #3 Re: correct spark plugs/wire set
    Dec 2011
    MN
    ok thanks,
    gotta replace the outer tie-rods, rear brake pads, fuel filter and coolant flush, AHHHH!
  4. #4 Re: correct spark plugs/wire set
    AH?
    Thats all easy stuff.
  5. #5 Re: correct spark plugs/wire set
    Dec 2011
    MN
    lol I know, been puttin it off since last summer, lol
  1. PRJ spark plug wire set??
    By TheManInBlack in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2013, 10:21 PM
  2. spark plug wire help
    By ryanmjw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 11:34 AM
  3. spark plug wire question
    By copperpacecar in forum General Tech Discussion
    Last Post: 05-12-2010, 12:20 AM
  4. Spark Plugs?
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 03:13 PM
  5. spark plug wire order help
    By SloEvil in forum General Tech Discussion
    Last Post: 08-16-2009, 04:19 PM
