Thread: Gas Leak?!
Results 1 to 9 of 9
  1. #1 Gas Leak?!
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Working under the hood again and I noticed a problem with one of the fuel lines:
    If I nudge it even slightly towards the UIM it sprays a stream of gas. This seems dangerous, especially with all the electronics surrounding it. I'm thinking I may have knocked it loose, but I can't seem to get it any more secure. Is this normal?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Gas Leak?!
    no.
    Struggle for a while to replace o-rings inside the black piece, or buy a replacement connector from a parts store and press it on or get the clamp style.
    Ohio
    What matt said^^^
    Go to the parts store and get a quick connect fix kit. Word of advise, don't mess with the barbs in the kit to connect the old and new lines. Just buy a compression union for nylon-nylon lines. It won't leak, every time I used the barbed connectors... They leaked.
  4. #4 Re: Gas Leak?!
    Kentucky
    So it just presses on? I didn't see any o rings. Is there a way to cut the gas feed so I can fix it without spraying gasoline all over the engine?
    2003 Grand Prix GT
  5. #5 Re: Gas Leak?!
    yes.
    remove fuel pump relay. then start the car.
    when it dies, try turning it over for 5 seconds.
    Will be lacking pressure.
    Will still have fuel in it.
    The barbed fittings need to be pressed in.
    There is a new "easy style" fuel line repair line of products out there.
    they simply slide into the existing nylon lines, then are clamped.
  6. #6 Re: Gas Leak?!
    Kentucky
    Well, I got a quick connect kit from Autozone, it was all they had. Looks just like the old one, with a metal tube to connect the old and new lines. Is there a way to keep it from leaking, or should I shop around for one of the clamp styles?
    2003 Grand Prix GT
  7. #7 Re: Gas Leak?!
    Ohio
    the tube youre referring to is the barbed connector. each time i used a barb, it leaked on either the old line or the new. i bought a compression fitting and used that instead.
    looks like this
    http://www.chicompany.net/images/05B01256.jpg
  8. #8 Re: Gas Leak?!
    Kentucky
    So just grab one of those and use it instead of the barbed connector? Okay.
    2003 Grand Prix GT
  9. #9 Re: Gas Leak?!
    Ohio
    make sure it is nylon to nylon though. itll be right where the quick connect kit was.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  4. LIM leak
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 10:37 PM
  5. oil leak
    By littlenoz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2009, 07:19 PM
