Thread: Strange Engine Sounds
Results 1 to 13 of 13
  1. #1 Strange Engine Sounds
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I've noticed a grating sound at stop while still in drive. The sound is similar to a starter turning after ignition, or like ABS brakes kicking in. I've only noticed it once before, but it doesn't sound good. It's not constant, it just grinds for a second or two and fades. I can only hear it if my door is open.
    Anyone know what this is?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Strange Engine Sounds
    Doesn't do it when you aren't in drive?
  3. #3 Re: Strange Engine Sounds
    Kentucky
    The last time was just after I shifted into park. I've only heard this three times now.
    2003 Grand Prix GT
  4. #4 Re: Strange Engine Sounds
    GT Level Member GMCustomerService's Avatar
    Michigan
    ShadowSwept,
    It may be a caliper piston to seal interface issue. See if you can duplicate the noise when the vehicle is not moving, by depressing the brake and listening for the noise from the wheel-well/caliper area. If so, I encourage you to take the vehicle in for inspection and repair.
    Please keep us posted.
    Louis
    GM Customer Service
  5. #5 Re: Strange Engine Sounds
    St. Louis
    Quote Originally Posted by ShadowSwept View Post
    Umm, GM Service, didn't he just say that it happened AFTER he shifted into Park already? Which by most peoples standards indicates that the car is not moving, hence the brakes are not being used.
  6. #6 Re: Strange Engine Sounds
    Kentucky
    I've been unable to replicate the sound so far. It did occur to me though that I've only noticed this when someone gets out of my passenger seat and I'm still at the wheel. It is possible I was holding the brake even though I was in park.
    2003 Grand Prix GT
  7. #7 Re: Strange Engine Sounds
    Being stopped though, rules out a caliper issue.
  8. #8 Re: Strange Engine Sounds
    Kentucky
    Well, it did it again; this time audible while still moving. I was pulling in to a parking place and my car let out a wail like a large bit drill through a block of wood. It didn't sound like it was coming from the wheel well, but it stopped once I let off the brake after shifting into park and hasn't done it again.
    Also, it was very wet today and my engine seemed to have the slightest bit more vibration than usual, and shifts felt a lot harder. Anyone know what's going on?
    2003 Grand Prix GT
  9. #9 Re: Strange Engine Sounds
    Try this.. turn your climate control totally off. If the noise stops, then it's likely your AC compressor.
  10. #10 Re: Strange Engine Sounds
    Kentucky
    I'll try that if I catch the sound again, but would this have something to do with that?
    http://www.grandprixforums.net/air-c...ket-59840.html
    2003 Grand Prix GT
  11. #11 Re: Strange Engine Sounds
    Houston....I think we found the problem.
    Likely your compressor clutch is fubared and causing the noise. Based on the ugliness in that pic..I'm going to think that's the likely possibility at the moment.
  12. #12 Re: Strange Engine Sounds
    Kentucky
    Okay, that should be fixed soon anyway, especially before the summer heat gets here . I'll post if that doesn't fix the problem. Thanks!
    2003 Grand Prix GT
  13. #13 Re: Strange Engine Sounds
    I assume you'll be looking at it soon. If you keep getting noise, untension the belt and try turning the pulley piece of the ac compressor by hand. It should turn smooth. Make sure you turn where the belt sits though..the front is part of the clutch and shouldn't be turning without freon in the system.
  1. More Sounds...
    By Remnant King in forum General Tech Discussion
    Last Post: 02-17-2012, 01:10 PM
  2. Strange engine noise
    By alvaradoguy2002 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-19-2012, 11:29 PM
  3. GT sounds like a gtp?
    By betsgtp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2010, 09:20 PM
  4. Engine weird sounds/chugging
    By ajm786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 09:18 AM
