Thread: Poor Fuel Economy - 2006 GP
Results 1 to 9 of 9
  1. #1 Poor Fuel Economy - 2006 GP
    Mar 2012
    Goliad
    2006 Grand Prix
    50k miles
    Naturally Aspirated
    I'm writing on behalf of a friend who is experiencing great pain at the pump due to the cost of fuel and poor fuel economy on his 2006 Grand Prix. Highway fuel economy has gone down from 25 mpg when it was new to 22 mpg. He is religious about keeping the tire pressure at 41 psi so we can eliminate that out of the equation. The car is stock, no Check Engine Light comes up and the engine runs good. What should be look into and/or replaced to restore the better fuel economy?
    Also, are there any worthwhile modifications that can be done such as better flowing mufflers or chips to make it less thirsty?
  2. #2 Re: Poor Fuel Economy - 2006 GP
    Out West
    Supercharged or Not?
    Whine with your Cheese?
  3. #3 Re: Poor Fuel Economy - 2006 GP
    41 is a little high, I would say 35psi alot better.
    Driving the speed limit is also key, these cars like 65-70mph for fuel economy.
    Do a tune up, new air filter, New Stock replacment plugs, Clean the throttle body to get rid of carbon build up. Make sure he is running the proper grade of gas for the car. 87 for NA motor and 91+ for Supercharged motors.
  4. #4 Re: Poor Fuel Economy - 2006 GP
    Pennsylvania
    Of course, we'd recommend loweing back down to 35psi for safety's sake.
    Maintenance at 50,000 miles:
    • Transmission flush + filter + trans reset
    • Coolant flush
    • Clean mass airflow sensor
    • Clean throttlebody
    • New intake air filter
    Modifications to increase fuel economy:
    • 9" cone intake filter sans box
    • Headers
    • Custom tune
    • Lighter tires
    • Lighter rims
    • Upgrade electrical grounds (Big 3)
    • Remove excess junk from inside car
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    How do you do a trans reset?
  6. #6 Re: Poor Fuel Economy - 2006 GP
    Out West
    unplug battery.
  7. #7 Re: Poor Fuel Economy - 2006 GP
    Mar 2012
    Goliad
    Quote Originally Posted by SlowNA06 View Post
    • Coolant flush
    • Headers
    • Custom tune
    • Lighter tires
    • Lighter rims
    What's "Upgrade electrical grounds (Big 3) all about?
    Any comments on which custom tune is best for fuel economy and what kind of increase are we talking about?
    How about O2 sensors?
  8. #8 Re: Poor Fuel Economy - 2006 GP
    Pennsylvania
    Quote Originally Posted by Compg4me View Post
    You can either leave the battery unplugged for a while - I think it's 20 minutes. This, of course, is done after the flush.
    Or, you can use a TechII to reset it.
    Quote Originally Posted by Edahall View Post
    You rewire your grounds with thicker wire.
    A custom tune means that a nice man sits in your car and tunes it for you with his laptop. That's the only kind there is.
    The O2 sensors are fine. Don't touch 'em.
  9. #9 Re: Poor Fuel Economy - 2006 GP
    Mar 2012
    Goliad
    Thanks for all the replies.
    Here's another thing. Due to allergy issues, my friend leaves his climate control on "recirculate" at all times. I believe this is causing the A/C compressor to run at all times and possibly reduce fuel economy 10-15%. Is there a way to keep the climate control from letting outside air in and at the same time, not turn on the A/C compressor?
  1. Fuel Economy
    By timreams in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-11-2011, 03:29 PM
  2. Bad fuel economy
    By Blackbird87 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-26-2011, 01:52 PM
  3. 04 GTP Bad Fuel Economy
    By pr84704p in forum 04+ Specifics
    Last Post: 01-16-2010, 08:10 PM
  4. poor fuel economy and surging
    By 513yj in forum General Tech Discussion
    Last Post: 07-25-2009, 10:34 AM
  5. Fuel Economy???
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 06-07-2008, 09:31 PM
