Thread: rough idle IF it cranks ?
Results 1 to 3 of 3
  1. #1 rough idle IF it cranks ?
    Mar 2012
    Florida
    doing some work on a 98 Grand Prix GT w/ 3800, will not crank unless your foot is on the accelerator and IF it does crank, it is idling extremely rough... suggestions please ...
  2. #2 Re: rough idle IF it cranks ?
    try unplugging the MAF sensor.
    Check for vacuum leaks, cheak all the vacuum lines for breaks
  3. #3 Re: rough idle IF it cranks ?
    Not nit picking, I was able to read through what you meant. For the future though..this may make it easier for others.
    Terminology.
    Crank, the physical turning of the engine via the starter.
    Running, when the fuel/air in the cylinders ignite and the engine turning itself.
    Starting, the process of cranking until the engine is running.
  1. rough idle
    By mcsddd in forum General Tech Discussion
    Last Post: 01-15-2012, 03:58 PM
  2. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  3. rough idle 02 gtp
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-06-2010, 01:16 PM
  4. 91 GP rough idle
    By Juanmiguel in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-04-2010, 11:07 PM
  5. Rough Idle
    By hacket in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 02:39 PM
