Thread: Oil pump going bad??? Ticky ticky
Results 1 to 20 of 27
  1. #1 Oil pump going bad??? Ticky ticky
    Michigan
    So a few days ago engine started ticking, on start up but would go away when the engine warmed up. (ticking seems to be from the top) would stumble some times until warm -- Cyl 6 Misfire code was thrown. Did seafoam, Drove about 50 miles, just did an oil change, some ticking then it went away. But then I noticed a sewing machine noise? coming from the passenger side (could the oil pump be failing?)
  2. #2 Re: Oil pump going bad??? Ticky ticky
    Antioch, IL
    oil pump is in the oil pan at the bottom of the engine.
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Oil pump going bad??? Ticky ticky
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Possibly lifter tick? does it get louder or faster as rpms get higher?
  4. #4 Re: Oil pump going bad??? Ticky ticky
    Michigan
    Quote Originally Posted by cameron92 View Post
    Yeah I think its a lifter, but why is it ticking?
  5. #5 Re: Oil pump going bad??? Ticky ticky
    carbon/sludge build up, not changing your oil often and allowing it to gum up.
    could be that.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Quote Originally Posted by ITHURTZ View Post
    Oh wow, really? Cause i swore that the oil pump is in the timing cover.....
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  7. #7 Re: Oil pump going bad??? Ticky ticky
    Michigan
    Quote Originally Posted by copgtp View Post
    Ok, Thought I was losing it then decided it was bad info, but was waiting to hear from someone else on this forum that it is under the front cover.
    Ohio
    Me too lol ^
    Orange County, NY
    Just goes to show the misinformation ppl get on this board .......
  10. #10 Re: Oil pump going bad??? Ticky ticky
    People mistake the oil pick up for the pump all the time.
    Orange County, NY
    Then maybe they shouldn't be giving advice.....
  12. #12 Re: Oil pump going bad??? Ticky ticky
    it is under the front cover, driven directly off the crank.
  13. #13 Re: Oil pump going bad??? Ticky ticky
    Hence the reason why it used to be thought and is still posted on ZZP's site about milling the oil pump cover to fit a double roller behind the timing cover.
    We also now know that ZZP's site was never updated for the information learned by Janice, Zoomer and a few others that was shared.
  14. #14 Re: Oil pump going bad??? Ticky ticky
    Michigan
    Back to the ticky ticky.... Changed oil and went with a 5w 30 to see if that would help reduce / emliminate the ticky... Well now its actually worst. Takes longer to go away, now it only goes away when the temp gauge is near its normal warm state? So I am thinking this is not a gunk issue. Still have seafoam in there but think its getting near time to take it to the shop.
  15. #15 Re: Oil pump going bad??? Ticky ticky
  16. #16 Re: Oil pump going bad??? Ticky ticky
    run some lucas oil treatment in it. It should help
    Orange County, NY
    Could you possibly post a video of the noise? It will b easier to diagnose.
  18. #18 Re: Oil pump going bad??? Ticky ticky
    Antioch, IL
    hey cop STFU. I mistaked the 2 parts. I know where each is my hands mis typed. You got a problem with that?
    Orange County, NY
    Everyone "mistakeded" stuff all the time. I correcteded your mistakeded though. No worries.
  20. #20 Re: Oil pump going bad??? Ticky ticky
    ^^^^^^^lol
  1. 42.5# Injectors, Flowjet pump, ZZP pump controller
    By StamperGTP in forum For Sale - Parts
    Last Post: 01-10-2012, 02:33 PM
  2. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  3. Oil Pump ???
    By TurboGTP in forum Turbo
    Last Post: 06-25-2010, 09:40 PM
  4. oil pump??
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 02:07 AM
