Thread: Stalls when warm and mis-fires at 4000 RPM
Results 1 to 8 of 8
  1. #1 Stalls when warm and mis-fires at 4000 RPM
    Jun 2010
    Bakersfield, CA
    2000 grand prix GTP. 140,000 miles. Idles fine when cold, but if you rev it up it mis-fires at 4000rpm. When it gets warm, it stalls.
    Changed plugs, wires, and coil packs. Cat is about 30 degrees hotter in front than back. Can't find any Vaccum leaks.
    Any help would be appreciated!
  2. #2 Re: Stalls when warm and mis-fires at 4000 RPM
    in Park you are revving it?
    If so thats the rev limiters.
  3. #3 Re: Stalls when warm and mis-fires at 4000 RPM
    Jun 2010
    Bakersfield, CA
    It is in park. The whole car will shutter, and the rpm will drop 1000 rpm. It will also stutter when revving it up at all rpm when it's warmed up. When idling warm, the rpm will roam a bit and it will randomly die. Restarts without issue. If you put it in drive and hold the brake and give it gas, it will shutter & die.
  4. #4 Re: Stalls when warm and mis-fires at 4000 RPM
    First off the car wont rev past 4000 rpm in park, because thats the rev limiter/fuel cut off.
    As for the car sputtering and dying, have you done a tune up lately?
    Are there any Check engine lights on the could help tell what the problem is?
    Some of these symptoms could be a faulty cam or crank sensor, thus telling the computer to cut spark and fuel and make it die.
  5. #5 Re: Stalls when warm and mis-fires at 4000 RPM
    Jun 2010
    Bakersfield, CA
    Replaced plugs, wires, dist. packs. New air filter. Have not replace fuel filter. Have not replaced any other sensors. There are no codes and no ces light on.
  6. #6 Re: Stalls when warm and mis-fires at 4000 RPM
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    check fuel pressure, could be a bad ign control module. honestly hard to diagnois. i would think its a spark issue.....maf? wow goodluck
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  7. #7 Re: Stalls when warm and mis-fires at 4000 RPM
    Jun 2010
    Bakersfield, CA
    So I've driven without major issues the last 2 days with the MAF sensor unplugged. It did Die going from the freeway to a stoplight. started right up and drove without a problem. Obviously the SES light is now on. Going to give it a couple more days, but it looks like a MAF sensor is in my future. Any suggestions for a quality one?
  8. #8 Re: Stalls when warm and mis-fires at 4000 RPM
    stock replacement.
    denso/delco
    and what ever you do, dont go WOT with it unplugged.
  1. Replies: 5
    Last Post: 09-04-2011, 01:47 PM
  2. turns over fires back fires then wont start
    By flyby713 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2011, 10:21 PM
  3. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  4. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
  5. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
