Thread: temp gauge/big changes problem
Results 1 to 5 of 5
  1. #1 temp gauge/big changes problem
    Nov 2011
    texas
    Hey all. So, my temperature gauge in the car started showing the engine not warming up properly some time ago: it would get to the first quarter mark, or just below on highway driving, but in city it would heat up fast and a good bit more. That problem didn't "seem" to be impacting anything, so i didn't worry about it (except to change the thermostat). Then just recently it got to where it won't even get past the very first marker line (from dead cold) on the highway, yet in the city, it will heat to the midway point or a little more. Since the second temp change, i check the engine every time i get out of the car, and it's not overheating,and perhaps not hot enough(but this could be faulty perceptions from me) Any ideas on what would be causing this?
    Thanks for your time,
    Jason
  2. #2 Re: temp gauge/big changes problem
    Have the car scanned for codes. If you don't have a P0128 which is the code for the engine not heating up properly. Then likely your coolant temp sensor or the wiring to it is it faulty.
  3. #3 Re: temp gauge/big changes problem
    May 2008
    staten island,NY
    Coolant temp sensor x2
  4. #4 Re: temp gauge/big changes problem
    Quote Originally Posted by QwikGT View Post
    I didn't say temp sensor though. I sayyyyyys maybe and gave him a test to check for it. X2 on that!
  5. #5 Re: temp gauge/big changes problem
    Nov 2011
    texas
    Replaced the sensor today, but still doing the same thing. The car is also shuddering under power after midway through second gear; not sure they are related, but i replaced the plugs and wires and it still happened. Any suggestions?
    Thanks
  1. Engine Temp Gauge
    By Phil318 in forum General Tech Discussion
    Last Post: 11-12-2011, 02:54 PM
  2. 04 grand prix gt temp gauge problem
    By Filion in forum General Tech Discussion
    Last Post: 01-26-2011, 05:22 PM
  3. Temp gauge
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 01:39 AM
