Thread: coolant and thermostat
Results 1 to 12 of 12
  1. #1 coolant and thermostat
    GTP Level Member
    Sep 2011
    Motown
    Well i am just a kid that knows some stuff bout motors but by far not an expert. I want to change my thermostat to a 180 degree and i was wondering if i could just clamp off the upper radiator hose and change it, or would i have to drain all the coolant then change it?
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: coolant and thermostat
    Pennsylvania
    You're better off just draining it. Pull off the lower rad hose... I had trouble with it the first time, but it's actually really easy. Coolant has to be changed every so often anyways so might as well get it done and learn that job too. You might end up just damaging the hose, and you're gunna lose a bunch opening that up no matter which way you go.
    Sport Edition Kv5 18x8
  3. #3 Re: coolant and thermostat
    if the motor is cold, just unbolt the thermostat housing and change it, you will maybe lose a a few cups of coolant, just add some back into the overflow tank.
    But why are you changing it tho?
    Going colder with net you less MPG's but only a small amount, these cars love to run at 195ยบ.
    And if you do change it, make sure you bleed the cooling system afterwards.
  4. #4 Re: coolant and thermostat
    GTP Level Member
    Sep 2011
    Motown
    What do u mean by bleed?
  5. #5 Re: coolant and thermostat
    taking the thermo out, lets air get into the cooling system, which will cause hot spots and make the coolant boil faster and could make motor go boom boom.
    So you need to bleed the cooling system with the bleeder on top of the thermostat housing.
  6. #6 Re: coolant and thermostat
    GTP Level Member
    Sep 2011
    Motown
    Ok thank you.
  7. #7 Re: coolant and thermostat
    I'm surprised you didnt ask how to do, because I'm sure you dont.
    Do everything to replace the tstat and put it back together. Then start the racecar and let it run up to operation temp, while its warming up, open the bleeder (1-2 turns) with a 7 or 8mm or screwdriver depending on what it has. Once its warm, air bubbles will start to come out along with some coolant, wait for it to be a steady stream of coolant and then close the bleeder and take it for a drive, if it starts to get hot, bleed it again to make sure all the air is out.
    Nov 2011
    Charleston, SC
    I'd just pull the drain plug out the bottom of the rad to drain it instead of pulling hose.
    Use prestone 50/50
    Sent from my SPH-D710 using Tapatalk
  9. #9 Re: coolant and thermostat
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Quote Originally Posted by MurphyGTP View Post
    Use prestone 50/50
    Thats quite a Easy solution. Although most of these cars are a few years old and the plastic becomes brittle. Nothing like taking a Simple job. And breaking the Plug or the Radiator Petcock housing. I dislike pulling the plugs.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  10. #10 Re: coolant and thermostat
    utah
    Pulling the hose will empty it faster and more complete then breaking the petcock trying to turn it
  11. #11 Re: coolant and thermostat
    Jan 2012
    Pennsylvania
    I have changed stats twice in two different prixs and also a few different times in other cars. The stat sits high enough on our cars that one really doesnt lose alot of coolent if none is drained from the rad befor the stat change. As far as bleeding the air out of the system I guess I got lucky because I never had that issue befor even though it's always talked about when some one does a stat change. Be sure to rince off all the coolent that has run down the the top of the motor it can really be corrosive and will show a few years down the line. As stated on used cars a bag of worms can be opened up if one brakes a peacock drain plug or even as I seen several air bleeders next to the stat hsg. If I have to drain the coolent I try the peacock plug with moderate pressure if that seems to tight then I just take off the lower rad hose and get ready for the rush of coolent As stated earlier make sure this is all done on a cool motor don't attempt if you just shut the car down. Good luck and like most of us here our stat was one of the first mods we did. Hope this helps
  12. #12 Re: coolant and thermostat
    I'm wtih the yank two bolts and dry up the garage floor after crowd here. It's really not that much coolant that you'll lose by not draining. Then the bleeding is so much quicker/easier.
  1. bad thermostat?
    By jwhite85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2011, 12:22 PM
  2. P0128 engine coolant too low, stuck thermostat?
    By thegipper in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2011, 12:32 PM
  3. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  4. Low Coolant Light...Thermostat?
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2008, 12:03 PM
  5. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
