Thread: Clicking and Sloshing behind dash!
Results 1 to 12 of 12
  1. #1 Clicking and Sloshing behind dash!
    Aug 2011
    Mesa, Az
    Hey all,
    So my 04 GT1 has water sloshing in the dash, heater stopped working and I can smell coolant but cant find a leak. I think it is a plugged up heater core... Are there any easy fixes? Or am I going to be paying for a $1000 job soon? Can it be bypassed in these cars? ALso, there is a weird clicking coming from behind the dash about 3 minutes after the car is shut off. It also does the clicking when I unlock the car with my clicker.... Is it an actuator? What is this noise it is very annoying.... Any insight?
  2. #2 Re: Clicking and Sloshing behind dash!
    Ohio
    bleed the coolant system. probably air in the lines
  3. #3 Re: Clicking and Sloshing behind dash!
    Cambridge, Ontario Canada
    Quote Originally Posted by 99PGPGT View Post
    yes
    2005 E55 - stock
  4. #4 Re: Clicking and Sloshing behind dash!
    Aug 2011
    Mesa, Az
    Even thought the heater isnt working?
  5. #5 Re: Clicking and Sloshing behind dash!
    Nov 2011
    Loves Park, IL
    I couldn't find a leak either but I was loosing coolant. Check your heater hose connector. On my 06 it was underneath the alternator. You will need to bleed the system to if that is the culprit.
  6. #6 Re: Clicking and Sloshing behind dash!
    Aug 2011
    Mesa, Az
    Quote Originally Posted by yetisn0wman View Post
    Was the hose bad or loose? Did you smell coolant also?
  7. #7 Re: Clicking and Sloshing behind dash!
    Ohio
    yeah, thatll cause loss in heat. can you hear the heater kicking on? but just no heat coming on? usually when you hear the sloshing around, its air in the system
  8. #8 Re: Clicking and Sloshing behind dash!
    Aug 2011
    Mesa, Az
    Ok cool. I will do that Saturday morning and hopefully that fixes it. How does the air get in the system? Also, does anyone know what the clicking behind the dash is it is annoying its behind the dash? Its definitely mechanical... I think its an actuator or something.
  9. #9 Re: Clicking and Sloshing behind dash!
    Quote Originally Posted by kwakuzulu View Post
    so the fan works but blows cold? and clicking in the dash right? do you hear the clicking only when you work the temp controls or all the time? and your not running hot or overheating or under cooling? temp gauge is ok?
    i would start with bleeding the system, if that fails it could be a actuator has a cracked gear in it, is it both sides are blowing cold?
    if you remove a actuator and turn the knob manually and get heat, you found your problem.
    heres a ling to how to remove them little buggers.
    http://www.grandprixforums.net/blend...ent-21941.html
    you could also lift the carpet to see if its getting wet under it to rule out the core leaking.
    and check you lim bolts for wetness, the bolts could be leaking. thats where my coolant was leaking from. i was loosing like 2 cups a week, not much but enough to notice it was missing. a flashlight in broad daylight will help see down there on the back side better.
  10. #10 Re: Clicking and Sloshing behind dash!
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    It's common for the plastic coolant elbows by the Alt to go bad. The 0-rings get eaten away and leak.You lose enough coolant you get air in the system and you can hear the sloshing in the heater core.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  11. #11 Re: Clicking and Sloshing behind dash!
    Aug 2011
    Mesa, Az
    Quote Originally Posted by Durk Diggler View Post
    Just had the elbow done a few months ago....
  12. #12 Re: Clicking and Sloshing behind dash!
    Aug 2011
    Mesa, Az
    I bleed the system for the third time and the overheating stopped. Now I have a leak on the right side of the motor, I had the shop pressure test; system is sealed.... ? They shop said it is leaking from the resoivor when it overheats... I call bull****... What do you guys think?
  1. Box under dash loud clicking
    By darkhorizon in forum General Tech Discussion
    Last Post: 08-11-2011, 09:11 AM
  2. Sloshing? WTF?
    By Mad Monkey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2011, 07:04 AM
  3. clicking sound under dash
    By CTKGP09 in forum General Tech Discussion
    Last Post: 07-15-2009, 01:04 PM
  4. clicking sound under dash
    Last Post: 06-23-2009, 08:05 PM
  5. Squeaking/clicking in dash, climate control?
    By jagamite in forum General Tech Discussion
    Last Post: 10-21-2008, 11:05 PM
