Pontiac Grand Prix Sway Link Replace - YouTube you can see it's independent of the LCA. See attached, the sway bar link connects from the strut assembly to the stabilizer shaft.
So a 97-03 LCA should be fine?
It just depends if it'd clear the sway bar mount on the LCA.
Look at your car and see how close the sway bar/link comes to the LCA.
Hmmm I'm not sure on the BJ's of the 04+ cars if they press in/out or bolt up like the 97-03's. That's right. Bolt up.
So it's good or not? lol
See in the pic..there are three things near the ball joint. On a 97-03 those are factory rivets. You drill them and the old ball joint comes out. Then the new one bolts into place.
04+ like I said..I am unsure. I'm not looking at one.
Gotcha, thanks for the explanation. I'm not well versed in auto parts (getting there), but I can tell you all about computers and networks
Replaced my elbows this afternoon, got it up to temp with the pump and heat going and no leaks!
What my problem elbow looked like
Point of failure
Going to do a proper coolant flush tomorrow when the coolant is cold. I can take pics of the LCA/sway bar link then.
The ball joints are riveted on the control arms on my 04. Just made a new topic in the suspension forum for the LCAs http://www.grandprixforums.net/2004-...tml#post779602
