Thread: fuel pump issue
Results 1 to 8 of 8
  1. #1 fuel pump issue
    Ohio
    i need pictures of the stock venturi system for a 99 gt. im confused on how the whole system works because the old pump looks identical to the venturi 255 i have in it, but the stock pump didnt have the small tube on it for the venturi system
  2. #2 Re: fuel pump issue
    Minnesota
    Ok here you go
    Venturi canister with the line going to the bottom:
    Top of canister with new connector:
    The black line connects to this nipple:
    The clear line goes to the underside of the top of the canister:
  3. #3 Re: fuel pump issue
    Ohio
    so does the small tube connect to the nipple on the top of the pump? or does it just sort of hang out there?
  4. #4 Re: fuel pump issue
    Ohio
    this is the top of the pump i got from tengis....apparently what he says is the metal piece on the outlet needs to come off? the bubble piece shown in this picture
  5. #5 Re: fuel pump issue
    Donating Users Tengis's Avatar
    Houston
    Yes, pull that metal piece off of the outlet. The metal piece is there for those that use a rubber hose.
    The little nipple goes to the black hose in the first picture of Pure2Sins post.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  6. #6 Re: fuel pump issue
    Ohio
    So Zack, that metal piece, does that restrict the flow with the plastic tube?
  7. #7 Re: fuel pump issue
    Houston
    No, but you cant really properly install the plastic tube with the metal piece on there. If you got the plastic tube onto the pump with the metal thing left in place then you are fine as long as pressure isnt leaking.
    Long story short though - the pump will die within 7-10 days without the venturi hose hooked up.
    Satin Purple 97 GTP
  8. #8 Re: fuel pump issue
    Ohio
    its coming off in the next couple hours
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Possible fuel pump issue.
    By SleeperGS in forum General Tech Discussion
    Last Post: 11-29-2011, 01:58 PM
  3. Help with an oil problem and fuel pump issue
    By deathjunior in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2011, 11:23 AM
  4. Fuel Pump Issue
    By zildjian102 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:17 PM
  5. Fuel Pump/Resistor issue
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 07:51 PM
