Thread: headers tapping front fan
Results 1 to 20 of 21
  1. #1 headers tapping front fan
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    So installed zzp square poly mounts and now my sdheaders are hitting the fan.... any cheap way to fix this i tore the stock mounts so cant put those back in.. i guess the fans shrouds are bigger on 04-05 impalas
    ill take a pic when im done work
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  2. #2 Re: headers tapping front fan
    i took the heat shield off on the driver side. it was hitting during the install. with it off it clears the fan by inches. but thats a 98 regal.
  3. #3 Re: headers tapping front fan
    I would do what Scotty said and try it with the heat shields removed.
  4. #4 Re: headers tapping front fan
    best o got for a pic, as its not of the clearance.
    the pass side shield is still there, just the driver side i pulled off.
  5. #5 Re: headers tapping front fan
    St Thomas Ontario
    Can I take the shield off with the header on?
  6. #6 Re: headers tapping front fan
    Quote Originally Posted by Grimsin View Post
    You should be able to. I had to remove mine for clearance too. Of course I'm American so I'm much more talented then all of Canada
    04 Comp G.
  7. #7 Re: headers tapping front fan
    i jammed a screw driver where its clip is, and tore it the f off. now thats talent lol
  8. #8 Re: headers tapping front fan
    Bingo same here
    04 Comp G.
  9. #9 Re: headers tapping front fan
    Oct 2011
    Toledo, OH
    Isn't it plastic? Should sort itself out lol...
    7"
  10. #10 Re: headers tapping front fan
    my shields are metal.
  11. #11 Re: headers tapping front fan
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    My 03 Regal had the SD headers hit the drivers side fan. It was actually resting on it. I let it go for 2 years and never really had an issue until I heard the fan cut in and out when I shut the car off. Pop the hood and look and there are sparks coming from the drivers side fan motor (where the header was hitting).
    I ended up having to find a set of '98 fans from a Regal and they gave me an extra inch of clearance. Apparently the 01+ Regals had a larger fan/shroud.
    first pic - Stock 03 Fans. 2nd - '98 Fans installed
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  12. #12 Re: headers tapping front fan
    Apr 2015
    Columbus, OH
    Same issue on 01 impala. I took shroud off. Header still hits fan, so I put some of that sticky backed aluminum heat wrap stuff on it. Dunno what its called but I love the stuff. Buddy gave it to me when a heat shield fell off my Sienna and the fan was melting. I used it in several places. Wrapped a little around the ect gauge. Stuffed and sealed a hole I drilled above exhaust to run my o2 sensor through. Some other places I can't remember.
    Top Swapped 01 Imp
  13. #13 Re: headers tapping front fan
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Just as the posts above, I also had to remove the fan heat shield off of my 04 Impala LS. Header sits pretty close to the plastic fan, no issues so far. The foil tape is a good idea though, I should try that.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  14. #14 Re: headers tapping front fan
    Banned
    Jan 2013
    maryland
    I have the same issue.. Wrapped the headers with header wrap and its hitting the fan.. Dont wanna trim the fan with the die grinder so i probably need to get something in between the fan and the header
  15. #15 Re: headers tapping front fan
    St Thomas Ontario
    wouldnt cause false knock though thats what im worried about..
    here are 2 pics of how close it is.
    video with my foot on brake giving lltlle gas to show what noise it make on take off.
    when i rev the engine and watch the header it doest move so at all but thats just free rev not in gear
  16. #16 Re: headers tapping front fan
    Nov 2011
    NY
    This issue is only with SD headers?
  17. #17 Re: headers tapping front fan
    St Thomas Ontario
    so where my header is hitting isnt a shroud but the actually fan motor correct? or is that a cover i cant take off?
    Quote Originally Posted by coolone View Post
    I have read its a regal and impala issue, and 04+ gp's
  18. #18 Re: headers tapping front fan
    looks like the fan itself is getting hit. time for a pair of 98 fans, or maybe some low profile after market fans. they work better, but are a bit louder.
    iirc i had pro comp fans on my last truck, 2, 16's was like 30 bucks. you'll need 2 smaller fans for sure.
  19. #19 Re: headers tapping front fan
    St Thomas Ontario
    ugh i dont want to do that....fak! lol
    I have some poly bushings on the way maybe it will pull the motor/headers back away form the fan, if the stock bushings are stock.
  20. #20 Re: headers tapping front fan
    if you were to get the after market fans, they plug right in pretty much and mount up easy enough. if they dont plug in all you do is cut and solder the old fans plug on the new fans.
  1. Replies: 1
    Last Post: 09-05-2013, 11:20 PM
  2. WTH is this tapping noise
    By dagger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2011, 10:53 AM
  3. tapping in engine
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2010, 11:13 PM
  4. Tapping power from Amp.
    By m0ng00se in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 07:57 AM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
