Thread: deleting rear O2 sensor
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: deleting rear O2 sensor
    Quote Originally Posted by aussie View Post
    Great link, except...
    Quote Originally Posted by OP
    its an 05.
    NOTE (07/17/2007): The circuit presented here is identical (give or take some component values) to every commercial MIL eliminator I have examined--at least a dozen. However, you may find that it does not work with newer (2001-1/2+) cars because of advances made in both engine control software and processing power.
  2. #22 Re: deleting rear O2 sensor
    Nov 2010
    I searched ebay, and there is not an option for a 98 grand prix. I would like to get one with connectors already on it so I do not need to splice into the harness. There is one link to a source that is over $50. Does anyone know of other sources that are not splice kits.
    Buffalo
    I have one from wbody never even opened it. It plugs into the harness. No splice
  4. #24 Re: deleting rear O2 sensor
    SE Level Member grandprixgtcv3's Avatar
    phoenix, az
    Can I purchase a PCM which the code P420 removed from it? I have a 2005 Pontiac Grand Prix GTP Comp G!! Out in Phoenix, Arizona if there is a Mil on they fail the stupid Emission test so I need this to pass emissions.
    grandprixgtcv3
  5. #25 Re: deleting rear O2 sensor
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    I have a 01 and my rear o2 sensors bad and I'm getting horrible mileage so IMO it's better to just put the o2 in like I will be doing when I get cash
  6. #26 Re: deleting rear O2 sensor
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Rear o2 doesnt didnf effect my mpg. I had a bad one that threw cel and I got the exact same mpg
  7. #27 Re: deleting rear O2 sensor
    Mar 2013
    Staten Island, NY
    Quote Originally Posted by Grimsin View Post
    Why do you gotta rub it in dude! Lolol
    Sent from my LG-MS910 using Tapatalk 2
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  8. #28 Re: deleting rear O2 sensor
    Dartmouth N.S.
    Ok, I've got a question that I'm inclear on, I've got a 03 gtp, bought a 3" catted sow pipe from zzp, so with tuning out the code using HP Tuner, no non-report, will the car run as efficient or will I'll still run rich but just not throw the code?
  9. #29 Re: deleting rear O2 sensor
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SuperChargedGTP View Post
    The way I understand it, the rear o2 is only monitoring the efficiency of the cat. It won't affect the trims. That's the job of the front sensor.
    Though, I have heard of some ecus trimming fuel if the rear o2 is out of bounds to protect the cat, not sure if this happens on our cars though. I just set mine to not report and disabled the cat check, or whatever it is. Its some test that the pcm does to richen the mixture for a bit after a certain temp. Just max out that temp in the tune.
    Top Swapped 01 Imp
  10. #30 Re: deleting rear O2 sensor
  11. #31 Re: deleting rear O2 sensor
    Apr 2015
    Columbus, OH
    I've read that thread before. I must have got lucky with my 01 because I've never seen the rich cycle. I thought it was because I maxed out the temp for the cat check?
    Top Swapped 01 Imp
  12. #32 Re: deleting rear O2 sensor
    Buffalo
    It will still run the test looking for the change between the front and rear sensor.
  13. #33 Re: deleting rear O2 sensor
    Apr 2015
    Columbus, OH
    Quote Originally Posted by crazyguy03 View Post
    That sux. So changing the temp doesn't stop it. So weld in another bung and stick the o2 back in using the spacer?
    Top Swapped 01 Imp
  14. #34 Re: deleting rear O2 sensor
    Buffalo
    Or turn it off using dhp
  15. #35 Re: deleting rear O2 sensor
    SE Level Member GERRY's Avatar
    Jan 2013
    Montreal QC CANADA
    nevermind lol
    Last edited by GERRY; 05-28-2015 at 06:48 PM. Reason: Not having English as a first language lol
  16. #36 Re: deleting rear O2 sensor
    Buffalo
    Dhp is the only way to turn off the cat test.
  17. #37 Re: deleting rear O2 sensor
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Yup, DHP and Tiny Tuner. The 01/02 cars can get away from it by using a 98 pcm but that won't work for an 03 car due to the change in trans controls for that year.
  1. rear o2 sensor
    By timmysgtp in forum General Tech Discussion
    Last Post: 09-18-2010, 09:31 AM
  2. rear o2 sensor
    By boostedgtp2003 in forum General Tech Discussion
    Last Post: 04-09-2010, 09:41 PM
  3. Removing rear O2 sensor
    By Black18Ice in forum General Tech Discussion
    Last Post: 11-06-2009, 02:51 PM
  4. rear o2 sensor
    Last Post: 02-22-2009, 08:53 AM
