Thread: Car hard to start sometimes.
Results 1 to 15 of 15
  1. #1 Car hard to start sometimes.
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Hi
    I have a 2002 grand prix gt n/a. Sometime when I go to start the car it takes a few turn overs to get going. Occasionally wont start the first time. Sometimes it seems like it has a slight missfire as well. I have installed new plugs, wires, fuel filter, air filter is good. Checked the ohms on the coil packs as well. I have to check the ohm on the injectors still. Any other suggestions?
    Thanks.
  2. #2 Re: Car hard to start sometimes.
    Oklahoma
    Have you been able to check the fuel pressure, just in case? It could be a few other things but that would be a good starting point and if that is good we can offer up a few other suggestions.
  3. #3 Re: Car hard to start sometimes.
    May 2008
    Ontario
    Ok thanks, I will put the gauges on sometime this week and get back with the readings.
  4. #4 Re: Car hard to start sometimes.
    Barksdale AFB, LA
    You mean it cranks for a little while longer than usual before it catches? Usually it's the fuel pressure regulator (FPR).
    2009 Subaru Impreza WRX STI
  5. #5 Re: Car hard to start sometimes.
    Oklahoma
    If thats the case just pick up the improved Borg-Sorenson FPR and be done with it. Pull the vacuum line off to the FPR and see if you get fuel coming out. If so its probably bad, but it still could be on the verge even if there is no fuel that comes out.
  6. #6 Re: Car hard to start sometimes.
    Barksdale AFB, LA
    Take the vacuum line off the FPR and smell the hole in the FPR. If you smell gas, it's leaking.
    FWIW, mine is leaking and has been for over a year. The only side effect is the few extra turns occasionally on a hot start. Not worth it to replace it yet.
  7. #7 Re: Car hard to start sometimes.
    May 2008
    Ontario
    Quote Originally Posted by Sabrewings View Post
    So this wouldn't cause any other issues such as feeling like a slight missfire on the highway or an occasionally slight stuttery idle upon start up?
  8. #8 Re: Car hard to start sometimes.
    Barksdale AFB, LA
    If it's bad enough, it's possible. I haven't seen it personally.
  9. #9 Re: Car hard to start sometimes.
    May 2008
    Ontario
    Thanks I will look into it any idea what a new regulator costs? Is it much work to change? I will have to ask at my old job when I get in there this week. I am more familliar with working on the old 3.1L. The 3.8 is new to me, haha.
  10. #10 Re: Car hard to start sometimes.
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Um... I had a Camaro that had this problem. Took a few turns to start.
    Replaced the started and was good as gold. Started first try like a champ!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  11. #11 Re: Car hard to start sometimes.
    May 2008
    Ontario
    Quote Originally Posted by Freebeer187 View Post
    Thanks for the input, but sometimes it will start and die right away so I am pretty sure the stater is good. There is no cranking problems at all.
  12. #12 Re: Car hard to start sometimes.
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by WhiteGT View Post
    Definitley not a starter problem.
    Sounds like a fuel problem to me for the most part. I'd suggest checking that route out first.
  13. #13 Re: Car hard to start sometimes.
    May 2008
    Ontario
    Quote Originally Posted by Street Wolf View Post
    I checked the ohm reading on the injectors yesterday, they were all good. I get a different ohm reading on the 3 coilpacks but all are fairly close, so I think they are ok. I also took the egr off and cleaned it out, but it was not too bad so I doubt that helped anything. I should stop by my old job and put the gauges on the fuel system and see how that is. I will try to do that today.
  14. #14 Re: Car hard to start sometimes.
    May 2008
    Ontario
    Today I checked the fuel pressure, was almost 50 psi so that is good. I also scanned the car and nothing came up bad, so I have no idea what is going on.
  1. HOW to and is it HARD?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-10-2008, 10:37 PM
  2. For all your hard to find car part needs!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-09-2008, 09:13 AM
  3. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
  4. Shifts are pretty hard...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2008, 11:13 AM
