Thread: Help With Temperature Gauge issue!
Results 1 to 7 of 7
  1. #1 Help With Temperature Gauge issue!
    Dec 2011
    Naperville, il
    Hi, Ive recently replaced just about everything for my cooling system on my grand prix. (New radiator, hoses, heater hose fittings, water pump, thermostat, coolant temp sensor). . The car has 185k and the cooling system was due for a overhaul. After replacing everything on the coolant system, the temp gauge seems to be giving an incorrect reading in the car.. it will fluctuate from about 220 to about 245 degrees in the car (which is pretty damn close to overheating according to the temp gauge), and i laser temped the thermostat housing, the block, heater hose fittings, and the readings never exceeded 215.. What would cause the gauge to read high like that? faulty coolant temp sensor? i have no service engine lights, low coolant lights or anything.. everything seems to be in good working order besides the gauge. Any help would be greatly appreciated. Thanks!
    * also i bled the system thoroughly using a bleeder funnel and opening the bleeder valve until a steady stream of coolant came out.
  2. #2 Re: Help With Temperature Gauge issue!
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I would get a scanner and read what the computer is seeing from the temp sensor instead of going by the crappy gauge on the dash. If the temp sensor is showing about the same thing your seeing with the gauge then I would assume that either the temp sensor was bad or the car is actually getting hot. And thanks for letting us know you bled it cause that woulda been my first suggestion...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: Help With Temperature Gauge issue!
    Dec 2011
    Naperville, il
    Thanks For your help, i will scan the vehicle tonight and see how it goes.
  4. #4 Re: Help With Temperature Gauge issue!
    Keep in mind..there are two sensors built into that one. One feeds the pcm and the other feeds the dash. If you see a difference, it's likely the sensor. If you see them alike...it could be a stubborn air bubble and or the wiring to the sensor.
  5. #5 Re: Help With Temperature Gauge issue!
    Dec 2011
    Naperville, il
    Thanks for your replies. I scanned the car today and the ECT reads on the scanner normal around 205-210 degrees while my gauge reads near 240. I do see the connector that plugs into the coolant temp sensor plugs into the harness near the fuel pressure regulator.. maybe its bad.. but i bought another coolant temp sensor just in case.. im thinking its faulty. It should be good to drive as long as the pcm is reading the temperature right, correct?
  6. #6 Re: Help With Temperature Gauge issue!
    Yes..as long as the pcm is seeing the right temp, you are ok.
  7. #7 Re: Help With Temperature Gauge issue!
    Dec 2011
    Naperville, il
    Thanks for your help
  1. Rpm Gauge issue
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-27-2011, 10:20 AM
  2. Temperature gauge fluctuates
    By wagatlng in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2010, 01:05 PM
  3. Erratic Temperature Gauge..HELP PLEASE!
    By gtpgrl2000 in forum General Tech Discussion
    Last Post: 08-12-2010, 05:50 PM
  4. boost gauge issue vid
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2009, 09:44 PM
  5. Is the temperature gauge accurate?
    By Summit670 in forum General Tech Discussion
    Last Post: 12-22-2008, 12:07 AM
