Thread: What sort of socket is required to remove the front exhaust crossover bolts?
Results 1 to 12 of 12
  1. #1 What sort of socket is required to remove the front exhaust crossover bolts?
    Tucson, AZ
    They are similar to torx, but have more points-- they are 12 points (very small points). The socket/tool goes inside the bolt head, but I can't seem to find the correct bit. Thanks.
  2. #2 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Jan 2009
    Tallahassee, FL
    You sure about a torx? Mine are just normal socket, 10mm if I'm not mistaken.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Omaha, NE
    Mine were also 10mm socket worthy.
    I checked the service manual and it doesn't say any special tools are required and shows normal nuts and bolts...
  4. #4 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Panama City Beach, FL
    It's not a Torx you need, rather, a Torch.
  5. #5 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Tucson, AZ
    Bah, guess someone must have replaced them with something else!! I found what it is, btw. I went to O'Reilly parts and saw what I needed, even though I already looked; guess I just overlooked it. The bolt requires a triple square driver.
    On a related note, one of the back bolts snapped off! I just finished drilling it out, and am about to go buy a through bolt and nut. It seems like on these cars, I'll fix one thing only to discover another problem.
  6. #6 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Florida
    Yeah, it's very rare to get the crossover bolts, or the rear manifold to downpipe bolts out, without breaking them. They get rusty, and get heat cycled until they are literally bonded to the exhaust.
    Make sure to coat the bolts so they dont rust again, and rotate tightening the bolts (dont tighten 1 all the way, then the other, and so on) That way the crossover seats correctly.
  7. #7 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Mine came off easy peezy
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  8. #8 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Jan 2009
    Tallahassee, FL
    I had one break off on the rear bolts and couldn't get a drill in there to drill it out, so I have a c-clamp as an exhaust clamp that's been working out great.
    77 Morris Garage B
  9. #9 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Quote Originally Posted by Sandman View Post
    Staying true to the locale I see.
  10. #10 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Tucson, AZ
    I'll admit, the C-clamp idea crossed my mind, but I was lucky enough to be able to drill through the old stuck bolt so maybe I'll save the C-clamp for my next repair
    All finished up, and it feels good, except for the damn P1655 code. If not for that, I'd be able to pass emissions tomorrow and be done with the wrenching on it.
  11. #11 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by 02 WS6 TA View Post
    Redneck engineering works lol
    77 Morris Garage B
  12. #12 Re: What sort of socket is required to remove the front exhaust crossover bolts?
    Tucson, AZ
    For the record, I needed to remove the throttle body to access the rear bolt, in order to drill it out. As we all know, removing the TB is really easy so it wasn't a big deal. The big deal was using a dull, old POS bit to get through the old bolt, which took me probably 40 minutes of drilling, spraying with WD-40, and more drilling.
  1. Front exhaust manifold bolts.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-30-2011, 09:52 PM
  2. exhaust manifold bolts
    By jaredbos 1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-25-2010, 12:09 AM
  3. Stock exhaust Bolts
    By Spartan GL in forum General Tech Discussion
    Last Post: 03-14-2010, 10:42 PM
