Thread: brake fluid
Results 1 to 7 of 7
  1. #1 brake fluid
    SE Level Member donalda's Avatar
    Dec 2010
    MD
    are you able to upgrade to dot4 fluid after the whole system has been flushed?
  2. #2 Re: brake fluid
    dot 3 and 4 can be mixed but dot 5 cannot
  3. #3 Re: brake fluid
    utah
    Most fluid is now 3/4 compliant now anyhow
  4. #4 Re: brake fluid
    DOT 5 is useless anyways.
    At least for a passenger car or race car.
  5. #5 Re: brake fluid
    Dec 2010
    MD
    cool. thanks guys! I replaced all lines and calipers on my car and put DOT4 fluid in it that I got from Tire Rack. with everything new and steel braided lines this car finally stops good. just wanted to male sure that the 4 did not mess up any seals.
  6. #6 Re: brake fluid
    Nope you should be good to go until they rust out again lol
  7. #7 Re: brake fluid
    utah
    buy my fbody calipers...then you can haz real brakes
  1. How dirty should brake fluid be before changing it?
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2011, 10:10 PM
  2. Brake Fluid Leak
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2011, 10:47 AM
  3. Low Brake Fluid??
    By jezzer in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 10:12 AM
  4. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  5. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
