Thread: Car stalling and revving up
Results 1 to 5 of 5
  1. #1 Car stalling and revving up
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    My car has been revving up on it's own almost got me in a wreck today. And now tonigh I was idling and it clunked and died. It started right back up but then sputtered when I accelerated. Seems to have most problems at idle
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  2. #2 Re: Car stalling and revving up
    Omaha, NE
    Have you checked for vac leaks?
  3. #3 Re: Car stalling and revving up
    Apr 2011
    Fargo
    Where are all the vac lines at? Is it just the ones towards the front on top that slide on and off easily?
  4. #4 Re: Car stalling and revving up
    Apr 2011
    Fargo
    Also sputters when turning
  5. #5 Re: Car stalling and revving up
    St. Louis
    There is also a vac line on the back of the UIM towards the middle. It's 2 lines- a big one and a little one. Spray some carb/brake cleaner around it and see if the tone of the motor changes. If so, then there's your leak. Might also help if you clean the MAF.
    If you rule out vac leaks then it may be necessary to clean the TB and replace the IAC.
  1. Engine revving but barely moving
    By MBigelow in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2011, 04:02 PM
  2. GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    By 93Chewbacca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 09:38 PM
  3. Revving when RPM's below 2000
    By Badley in forum General Tech Discussion
    Last Post: 03-31-2011, 08:44 AM
  4. Rapping/Rattle at Idle, goes away when revving
    By hoont79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 05:25 AM
  5. Engine Revving after filter change
    By mikeh in forum General Tech Discussion
    Last Post: 01-18-2010, 12:29 AM
