Thread: Engine Temp Fluctuation
Results 1 to 4 of 4
  1. #1 Engine Temp Fluctuation
    Oct 2011
    Bluffton
    I have a 1997 gt with about 117,000 miles on it and the temp seems to be doing some strange things. When I am driving the car the temps will usually stay around 160-170, however when I am in traffic, stopped or driving really slow, the temps seem to rise pretty fast to about 200-210, at which point my fans come on and it stays at that temp. There is no overheating but I have never had a car that did that. Is it possible that I may have air in the coolent lines or a bad thermostat? The thermostat seems unlikely but it just seems weird to me that it does that.
  2. #2 Re: Engine Temp Fluctuation
    St. Louis
    Nope. That is totally normal. These engines run hot from the factory. The fans are programmed to come on around 210* IIRC.
    If you want you could flush out the coolant and refill. If that is the original DEX in there then its overdue. You could then refill w/ standard green coolant if you want, as long as ALL of the Dex is flushed from the system.
  3. #3 Re: Engine Temp Fluctuation
    Oct 2011
    Bluffton
    I know that the engines seem to run around 210 but should it be running so cool when I am driving it? Most cars I have had run at around the same temp after they reach operating temp and don't go up and down all the time like this one does.
  4. #4 Re: Engine Temp Fluctuation
    Antioch, IL
    thermo stuck open if ur going to 160. Mines stuck open though and even 30degrees outside it doesnt hit 160......
    2009 Challenger SRT8
    Expert at being gay.
  1. Engine Coolant Temp Fluctuating
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-29-2013, 04:33 PM
  2. Weird engine temp problem
    By Rivmage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2011, 06:59 AM
  3. engine missing and bucking at operating temp
    By jkirkwo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2011, 11:22 PM
  4. Engine temp question
    By toolguy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2009, 09:42 AM
  5. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
