Thread: Safety Stat
Results 1 to 8 of 8
  1. #1 Safety Stat
    Bellevue, Neb. Close to Omaha
    Anybody out there ever use one of those safety thermostats? These are the type that will lock into the open position if overheating occurs.
    I've installed three of them in our '04 GP. I get the PO126 (PO128?) code and the culprit is a thermostat that is stuck open.
    I think the one I just put in (warranty replacement) is stuck open already. I was offered a regular thermostat this last time and I think I will get one the next time.
  2. #2 Re: Safety Stat
    Omaha, NE
    "Safety Theromosts" suck more than Brett Favre after his first "retirement".
    Get a normal Thermostat or you'll regret it.
  3. #3 Re: Safety Stat
    drill a small hole in it. save money from buying a 'drilled' thermostat. done.
  4. #4 Re: Safety Stat
    St. Louis
    ^This^.
    And is a "safety" thermostat?? I've never had an issue w/ any of the normal kinds in say, well... ever. If they break and stick shut so what? Pull it and replace it. I'd be more pissed that I would have had to replace the thermostat 3 times by using the "safety" version. I hate bleeding the cooling systems on these motors, lol...
  5. #5 Re: Safety Stat
    I've run a safety stat and had no issues. Spade...what makes you dislike them, bad flow or issues?
  6. #6 Re: Safety Stat
    Kansas
    I've ran em before. Had one.... popped open, replaced it..... popped open again..... said eff it and threw a stock tstat back in. Not worth the hassle imo. If one fails, replace it with a stock one... never had one fail.
  7. #7 Re: Safety Stat
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Ran one once on my old GT and within a week it had popped and i went straight back to traditional... And yes I had it bled perfect with the "saftey one"
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  8. #8 Re: Safety Stat
    Yeah you guys are pretty much spot on. I went to return my fourth defective safety stat and the parts counterman point blank said, "dude, those are junk I never sell those!"
    Needless to say, I exchanged my defective safety stat for a stock style replacement.....got $5.35 back for the difference too.
    Lesson learned.
  1. E85 Talk about a safety net!
    By OrangeL67 in forum General Tech Discussion
    Last Post: 07-17-2011, 11:08 PM
  2. Neutral Safety switch harness
    By kissmyss in forum Off Topic Discussion
    Last Post: 11-11-2010, 03:09 PM
  3. Neutral Safety Switch
    By Roadzombie in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2008, 09:39 PM
  4. Important Safety Notice
    By stugots in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 11:33 AM
