Thread: Back to stock... Have a few issues.
Results 1 to 20 of 23
  1. #1 Back to stock... Have a few issues.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I finally got my car back to stock. I'm having a few problems though.
    NOTE: The car doesn't want to start on the MAF, so I'm running in speed density. Also, there is a minor exhaust leak. I haven't had time to fix these issues, but I'm not sure they are the cause of my problems anyway.
    1. The car surges at idle, and RPM goes up and down.
    2. The fuel trims are reading CRAZY negative values. I saw -40 at one point. Not sure if this is MAF related? I can also smell raw fuel in the car on startup.
    3. Engine still makes light scraping noise at around 2000 RPM. I'm not expecting anyone to solve this, but I thought I'd ask anyway.
  2. #2 Re: Back to stock... Have a few issues.
    Ohio
    check all your fuel fittings and everything, injectors too. if you smell raw fuel there has to be a leak somewhere. do a fuel pressure check to
  3. #3 Re: Back to stock... Have a few issues.
    Didn't see any leaks but I'll check again. I also forgot to mention, I'm still running GTP injectors, and the Autolite 104 plugs. I have a GT tune on it though...
  4. #4 Re: Back to stock... Have a few issues.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    GT tune, probobly based off of GT injectors?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Back to stock... Have a few issues.
    Ya. What table should I change buddy? Should I keep the MAF table and VE table stock, but use all the GTP injector tables?
  6. #6 Re: Back to stock... Have a few issues.
    Hagerstown,Md
    Yep
  7. #7 Re: Back to stock... Have a few issues.
    Changed injector flow rates to GTP values. Now the car either starts up for a second, then dies, or it starts up fine, runs for a minute, then dies out of no where. Same thing is happening whether MAF is plugged in or not.
  8. #8 Re: Back to stock... Have a few issues.
    Even changed the values back. It doesn't want to stay running, unless I hold my foot on the gas.
  9. #9 Re: Back to stock... Have a few issues.
    Figured out the idle/starting issue. The IAC was all gunked up. The MAP and MAF were also bad. As for the metallic noise, I throttled up the engine a bit and put my head down by the timing cover. It's definetely coming from there. It sounds like the chain is rubbing on something. .
  10. #10 Re: Back to stock... Have a few issues.
    PA
    Did you replace the tensioner when you did the cam?
    Oh, and does the car run on the MAF since you cleaned the IAC?
    2001 GSE
  11. #11 Re: Back to stock... Have a few issues.
    Quote Originally Posted by Zef_66 View Post
    Tensioner was replaced. The car runs on the MAF yes.
  12. #12 Re: Back to stock... Have a few issues.
    PA
    So your car runs good now. Great.
    So the only issue is the grinding. What chain set did you use?
    2001 GSE
  13. #13 Re: Back to stock... Have a few issues.
    Stock timing chain.
  14. #14 Re: Back to stock... Have a few issues.
    Something is rubbing and it doesn't make any sense. Everything in there is new, and I've torqued everything down. When I took it off before, I noticed the cam sprocket had been rubbing on the front cover. I'm assuming this is the same issue... But WHY!?
    I also noticed I am getting a high pitched whine coming from the engine under acceleration. It almost sounds like a turbo.
  15. #15 Re: Back to stock... Have a few issues.
    Hagerstown,Md
    Burn that damn car man. Its cursed! lol
  16. #16 Re: Back to stock... Have a few issues.
    Anyone got any ideas?
  17. #17 Re: Back to stock... Have a few issues.
    pull the timing chain cover and look?
  18. #18 Re: Back to stock... Have a few issues.
    I just pulled it for the 15th time to replace the damaged cam sprocket and thrust plate. Torqued everything back up, installed everything properly, and BAM, same noise.
  19. #19 Re: Back to stock... Have a few issues.
    sell it to an unsuspecting victim? lol
  20. #20 Re: Back to stock... Have a few issues.
    I wanted to fix it before I sell it. I'm afraid the timing chain/gears are going to come apart and ruin the motor.
  1. stock l32 spring size dyno issues
    By rodman in forum Turbo
    Last Post: 01-03-2010, 09:22 PM
  2. Old product comming back!! NEW PRICING!! In Stock!!
    By TDCRacing in forum Off Topic Discussion
    Last Post: 05-29-2009, 06:22 PM
  3. Long story short - want to get back to stock exhaust
    By OmahaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2009, 08:56 AM
  4. Issues with the stock air fliter box
    By Dagujugrandprix08 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 11:53 PM
