Thread: Low oil level AND oil pressure light
Results 1 to 9 of 9
  1. #1 Low oil level AND oil pressure light
    Oct 2011
    Iowa Park, TX
    Just did a motor swap after my wife's 2003 Grand Prix GT died with 170k on it. The new motor starts and runs fine with no unusual noises. The oil pressure light will come on after 15-30 seconds of running and then later the oil level light will come on. It does have oil and it is getting oil to the rockers. All sensors are hooked up. Is there any way to test the sending unit or maybe even the tan and black wires that come off of it? Could I have pinched a wire or two and that be causing the problem? Any help is appreciated!
  2. #2 Re: Low oil level AND oil pressure light
    St. Louis
    Could be a bad pressure sensor. And the low oil level sensor is in the front of the pan and those wires are easily cut when installing a new motor. Not sure how to test the pressure sensor. That is a normally open circuit IIRC. It only closes when you have about 5psi, which is usually too late.
    If that fails I would get a true oil pressure gauge on there right away just to be sure the pressure really is what its supposed to be. Just install the sending unit where the stock sensor is and see what you get.
  3. #3 Re: Low oil level AND oil pressure light
    I'd be concerned. If oil return was blocked, that could cause the symptoms. Sure it woudl run fine for a while as it probably gets oil returned slowly.. but yeah.
    I'd fire it up with a mechanical oil pressure gauge on it. That tells you w/o any doubts if your light is incorrect. Then watching that, I'd check the oil level when it's running. I know this shouldn't give a good reading as oil should be flying everywhere. But if the dipstick comes back dry..you know there's an oil return issue.
  4. #4 Re: Low oil level AND oil pressure light
    Oct 2011
    Iowa Park, TX
    Thankds for the help guys, It is going to sit till I can get a gauge on it. It is just strange that it comes on after running for a bit. It hasn't been driven or eveb ran for anytime once the light came on. Any other ideas out there?
  5. #5 Re: Low oil level AND oil pressure light
    Oct 2011
    Iowa Park, TX
    When I first started it one of the coolant Elvis wasn't completely seated and got the oil pressure sensor wet, could that be effecting things?
  6. #6 Re: Low oil level AND oil pressure light
    It shouldn't. All our conectors should ahve a rubber seal on them.
    Is your rubber seal in place? Are your wires good?
    The level sensor is totally seperate from the pressure sensor. Which is why when you said low pressure then the low level happens. That would point the pan being drained of oil. Which asks the question of where did it go... which is only answered by .. stored somewhere in the engine. Which leads me back to some clogged oil return. which is very uncommon and has only happened with improper head gasket install etc from what I've seen.
  7. #7 Re: Low oil level AND oil pressure light
    Oct 2011
    Iowa Park, TX
    Only gaskets changed were upper and lower intake (cause it was out and easier to do) and oil pan gasket. I did pull the oil filter housing by am certain that he spring went in first then the little metal cup.
  8. #8 Re: Low oil level AND oil pressure light
    I don't see how oil pressure would be an issue then. Add on the low oil level and it wouldn't make sense..
    Best to be safe and use a gauge.
  9. #9 Re: Low oil level AND oil pressure light
    Oct 2011
    Iowa Park, TX
    Agreed.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Phantom, intermittent LOW COOLANT LEVEl light, + other fun stuff
    By EricR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2011, 03:26 PM
  3. Oil Level Light problem likely the sending unit?
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 08:48 AM
  4. Oil pressure light came on help....
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 06:59 PM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
