Thread: P0306 and misfire; need opinions.
Results 1 to 3 of 3
  1. #1 P0306 and misfire; need opinions.
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    Sorry for the long read, just being descriptive.
    Cliffs:
    Low RPM misfires under increasing/high load
    Comes and goes
    No visible physical cause
    Tried:
    Swapping a spare TPS sensor: no change
    Swapping injectors 4 and 6: no change
    Swapping in a spare 3/6 ignition coil: no change
    Tested for a vacuum leak: no change
    Harsh language: no change
    In-Depth:
    So my 2000 GT is experiencing random misfires in the 1500-2200 RPM range when under high load. For instance, I'll be cruising in fourth gear and converter locked, doing 48 mph, and as I come to a slight hill, I tip into the throttle and it immediately begins to misfire, getting progressively worse, until I let off and tip in enough to downshift. It will misfire in this situation in second or third gear as well.
    However, if I floor it at 35 mph, it'll grab first, pull with a stutter here and there, shift great, then pull through that gear with more hesitation as well. But if I'm on the highway doing 63 mph or ~2250 RPM it will only sometimes buck. It comes and goes without any notable pattern...
    As this does not set a code unless I really abuse it, I'm thinking a component failure somewhere upstream of the plugs, as I've checked them all and they were immaculate. Once it finally threw a code and it gave me a cylinder 6 random misfire, but after inspecting the plug wire, plug, coil, and cps wiring, I could find nothing wrong. Start her up and voila, she's fine for a month and then it comes back...
    Any ideas?
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  2. #2 Re: P0306 and misfire; need opinions.
    I'd try harsher words.
    Kidding aside though...it could be a wire on it's way out...as nice as it looks...if it is only making a connection part of the time...how old are the wires?
    Also, you could try seafoaming it...could be a sticky valve if it has higher mileage on that cylinder...
    Or, since it is free...take your ICM off and have it tested at your local auto parts store.
  3. #3 Re: P0306 and misfire; need opinions.
    Arvada, Colorado
    Plug wires arent more than 20k old. I'm going to swap the 2 & 6 plugs and the 4 & 6 plug wires, to see if/where it moves. Then I'll have tested what I can, and after that, I guess I'll seafoam it and see how it feels. Thanks, blue.
    Sig2
  1. Misfire?!
    By Points70 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:37 PM
  2. Misfire?
    By Sabzz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2010, 10:52 PM
  3. Help! P0306 code!
    By Shutzero in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 08:53 AM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Misfire
    By munkee in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2009, 06:46 PM
