Thread: er rocker 1.8 & 1.85 visual difference?
Results 1 to 9 of 9
  1. #1 er rocker 1.8 & 1.85 visual difference?
    May 2008
    Winnipeg, MB
    the rockers came shipped to me all wrapped up in newspaper because they were used. I can't tell which ones are the 1.8 and 1.85, other then a small pin hole at the top of the one on the left in the picture. the 1.85 needs to mounted above the spark plug and 1.8 above the exhaust so its kinda important.
    2007 Pontiac Grand Prix
  2. #2 Re: er rocker 1.8 & 1.85 visual difference?
    Florida
    If I had to guess i would say the one on the left is 1.8 and the right is 1.85. You can clearly see a lil difference between them but idk man. Too bad the person before didnt seperate and label them.
  3. #3 Re: er rocker 1.8 & 1.85 visual difference?
    Did you try to contact the seller?
  4. #4 Re: er rocker 1.8 & 1.85 visual difference?
    May 2008
    Winnipeg, MB
    yes and waiting on a response
    email zzp? they gotta know
  5. #5 Re: er rocker 1.8 & 1.85 visual difference?
    Portland Oregon
    Flip them upside down and look where the pushrod goes on the rocker. The ones with the dimple closer to the trunion are higher ratio
  6. #6 Re: er rocker 1.8 & 1.85 visual difference?
    May 2008
    Winnipeg, MB
    Quote Originally Posted by OH4CompG View Post
    left rocker is the higher ratio correct?
  7. #7 Re: er rocker 1.8 & 1.85 visual difference?
    Portland Oregon
    Correct!
  8. #8 Re: er rocker 1.8 & 1.85 visual difference?
    May 2008
    Winnipeg, MB
    Correct!
    thank you
  9. #9 Re: er rocker 1.8 & 1.85 visual difference?
    Dec 2008
    Lawndale, CA
    They are not etched at all? Mine had a light etch to tell them apart.
  1. Audio and visual help!!
    By blortz in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2011, 05:36 PM
  2. Cheap Visual Mods
    By grandprix17 in forum Visual/Body Modifications
    Last Post: 10-24-2010, 09:00 PM
  3. my first visual mod!
    By hourang in forum Visual/Body Modifications
    Last Post: 06-21-2010, 09:22 AM
  4. First wax and first visual mod
    By prixgt01 in forum Visual/Body Modifications
    Last Post: 05-26-2010, 10:48 PM
  5. Cheap visual aesthetics
    By Firebird789 in forum Visual/Body Modifications
    Last Post: 01-13-2010, 11:51 PM
