Thread: Exhaust Manifold Gasket's
Results 1 to 8 of 8
  1. #1 Exhaust Manifold Gasket's
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey forum,
    I know I am still fairly new to modding 3800's so please don't be to harsh on me for asking this. I am thinking about trying to port the stock exhaust manifold on my 99 GPGT, my question is are the stock exhaust manifold gaskets reusable or do you need to toss 'em in the trash after you take them off. I have next to no money to spend on this so if I don't have to buy new gaskets that would be great. Any help you can give would be greatly appreciated.
    Thanks,
    Tgarison
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Exhaust Manifold Gasket's
    Charles City, IA
    They are reusable.
    SMGPFC Two Nipple General
  3. #3 Re: Exhaust Manifold Gasket's
    Abilene, Tx
    Thanks,
    It will more then likely be the middle part of next week before i can get started on this. How much of a pain is it to remove the rear manifold?
  4. #4 Re: Exhaust Manifold Gasket's
    Charles City, IA
    Just port the front, little to no gains from teh rear.
  5. #5 Re: Exhaust Manifold Gasket's
    Abilene, Tx
    Ok thanks.
  6. #6 Re: Exhaust Manifold Gasket's
    Quote Originally Posted by TheOtherNick View Post
    That and you'll probably snap the crossover bolts that go to the rear manifold.
  7. #7 Re: Exhaust Manifold Gasket's
    Abilene, Tx
    Hey dsmuts,
    Well just like you said when I tried to get the crossover bolts out i broke the two going to the rear manifold, my question to you is this do you know how to get those stupid bolts out with out removing the rear manifold? More specifically do you know what size socket i need to remove them? I have tried the following sizes with no luck: 13mm, 14mm, 15mm, 5/8, 16mm. Any info you can give me would be very helpful.
    Thanks in advance,
    Tgarison
  8. #8 Re: Exhaust Manifold Gasket's
    Texas
    Do what I did. Cut the stud off and the drill out the rest of the stud(and welded nut if needed). Then replaced it with 2 bolts and nuts.
    As stated don't worry about rear manifold. I have pictures in my build thread click the link in my sig 1st or 2nd page.
    85 Corvette
    01 TA
    03 Z06
  1. Stage two intake manifold gasket
    By 01gpgt01 in forum General Tech Discussion
    Last Post: 02-14-2011, 09:54 PM
  2. lower intake manifold gasket
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2010, 09:26 PM
  3. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  4. Intake manifold end cap gasket
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 07:01 PM
  5. Intake manifold gasket
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 09:38 PM
