Thread: Check Engine Light
Results 1 to 4 of 4
  1. #1 Check Engine Light
    SE Level Member probuilder1's Avatar
    Jul 2008
    VA
    Hey everyone, new here first post hope someone can help. It's a 1999 Grand Prix GT 3.8 and I had the codes pulled and here they are P0449, P0440, P0102, P0141.
    P0449 - The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid.
    P0440 - The PCM has determined that a malfunction exists in the evaporative emission control system.
    P0102 - The PCM has determined that the mass air flow imput is lower than expected for the current engine operating conditions.
    P0141 - The PCM had determined that a malfunction exists in the heater circuit for oxygen sensor 2 in bank 1.
    Any info on this would be greatly appreciated.
  2. #2 Re: Check Engine Light
    Barksdale AFB, LA
    Your MAF is bad, your EVAP solenoid is bad, and your rear O2 sensor is bad.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Check Engine Light
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Good call. I have a maf that I will sell you if you need one probuilder1 along with an evap solenoid also. PM me if you need them. Thanks
  4. #4 Re: Check Engine Light
    TDCRacing
    Guest
    PM replied to
  1. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  2. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
  3. Check THIS out!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 06-18-2008, 07:04 PM
  4. Check engine light and horrible miss...
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 07:53 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
