Thread: Intermittent P0171 code
Results 1 to 4 of 4
  1. #1 Intermittent P0171 code
    Ft Worth
    I've read the rest of the posts but this code gets thrown so intermittent, I can't believe it's a vac leak. I captured the data the last time it threw ( have an AutoXray 7000). The A/DF went to 13.2:1 vice the 14.7:1 and the TP angle went to 90.6 degrees (TPS A/D(V) went to 3.5 from 1.5 and back to .3 on the next drive cycle. I"ll check the vac system to make sure but what do you guys think about a bad throttle position sensor? The car is still in open loop so the O2 sensor should be ignored. Any thoughts? Opinions are welcome also!
  2. #2 Re: Intermittent P0171 code
    Ft Worth
    Cleaned the MAF last night and put it back in. Ran worse. Picked up a new one this morning and it seems to have cleared the problem. No P0171 after a 15 minute test drive. It was picking the code about every minute or two last night.
  3. #3 Re: Intermittent P0171 code
    Sweet
  4. #4 Re: Intermittent P0171 code
    Ft Worth
    3 hours of driving with a scanner hooked up set to record on any code and nothing popped. At least my son can get to college and back now without taking my car!
  1. Hi I'm new and have a p0171 code, can you help?
    By falconjohnd in forum Engine
    Last Post: 12-15-2011, 07:45 AM
  2. p0171 code, AEM WB reads good AFR
    By JayGTP02 in forum General Tech Discussion
    Last Post: 08-14-2011, 12:11 PM
  3. code p0171 p0332 wont start now
    By juanathandavid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 05:29 PM
  4. code P0171 keeps coming back
    By grandprix01 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2009, 01:33 AM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
