Thread: catalytic converter repair?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: catalytic converter repair?
    WBody exhaust sucks...I'd never go 2.5" on anything 3800.
    Also...this is in the N/A section...noobsauce
  2. #22 Re: catalytic converter repair?
    nowhere
    Here ya go...
    ZZ Performance
    3" bolt-in WITH a cat...$189.99 + S&H.
    To have an exhaust shop bolt it in for you...probably 20-40 bucks...I wouldn't pay more than that.
    Worthwhile upgrade too...as you'll notice gains not only in performance, but MPG's as well.
    thanks a bunch man, greatly appreciated. but i see for the 3" bolt-in with a cat for $150, am I supposed to add some of these add-ons?
  3. #23 Re: catalytic converter repair?
    Hang in man.. likely we can get you fixed up for much less. Most ZZP cats are high flow and won't pass emissions
  4. #24 Re: catalytic converter repair?
    If you were around these parts...no one gives two sh1ts about emissions...I'm sure there is someone up there with some fast cars that knows someone that'll pass yours for some extra cash under the table
  5. #25 Re: catalytic converter repair?
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Im noobsauce-ish lol. Sucks I paid $50 for mine to be put in. Well actually it was already in apperently I just suck so It was leaking so more of a fix there. Everything is expensive around here tho. OP just listen to blue and pretend I wasnt even here lol
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  6. #26 Re: catalytic converter repair?
    Ok, no tailpipe in mass. They connect OBD2 looking for the code and typically do visual for eGR and cat.
    This is easy to fix.
  7. #27 Re: catalytic converter repair?
    Oct 2008
    IL
    Happy they dont do visual in Illinois. They do when they see a built Z or somthing pull up.
  8. #28 Re: catalytic converter repair?
    nowhere
    thats great to hear! so a high flow cat would be acceptable then right?
  9. #29 Re: catalytic converter repair?
    Right...with a little programming
  1. catalytic converter
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 11:49 PM
  2. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
