Thread: Race Car Losing Power
Results 1 to 20 of 23
  1. #1 Race Car Losing Power
    SE Level Member BuschLightBandit's Avatar
    May 2011
    Hey everyone. I help out a guy who races a '98 non supercharged car. The car starts out the night really strong but, we seem to be losing power as races go on. Also this past weekend the car got pretty hot and it sounded like "walnuts in a tin can" (Race Car Driver's Words). After the race the car cooled to about 200* and it was just fine. I am wondering if this is common for this engine to do this. If not, is there anyway to fix this problem or trick the computer somehow so we don't lose power. Also is it common for this engine to heat up so quick?
  2. #2 Re: Race Car Losing Power
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Just from the sounds of it your engine is overheating and going into limp mode until it cools off. So the only way to change that is to keep the car cooler... You dont want to "trick" the car into thinking its running cooler than it is... If you try that the engine will run way to hot and go boom.
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: Race Car Losing Power
    Nov 2008
    Waterloo, Iowa
    I think our stock t-stat's are 195*, so it sounds like you're running pretty hot. Check your coolant?
  4. #4 Re: Race Car Losing Power
    Feb 2009
    flintnasty MI
    There are tons of things that happen in the fueling calculations past 220 degrees... I would not be pushing a supercharged car when it is that warm myself, but you can disable/push out alot of those temperature related safety items.
  5. #5 Re: Race Car Losing Power
    Jul 2010
    Michigan
    He states its NA.
    2005 GTP Grey
  6. #6 Re: Race Car Losing Power
    Feb 2009
    flintnasty MI
    Oh, thanks for that, I saw "supercharged" and just connected the dots...
    Either way, I suppose if you want to run it that hot... Toss 6 quarts of oil in, and either trick the temp sensor into reading lower, or have your PCM programmed to take out most of the safety functions.
  7. #7 Re: Race Car Losing Power
    Jul 2010
    Michigan
    I did the same thing at first when I read non supercharged... i just ignored the non
    2005 GTP Grey
  8. #8 Re: Race Car Losing Power
    any chance the a/c condenser is still up in front of the radiator? if so it may be all caked up with dirt. or maybe the radiator its self is caked up too. dirt track racing? you dont say. maybe get a lower t-stat in it and a better fan installed, and tune the fans to turn on sooner.( or just put a manual switch on the fans) im sure you are running the piss out of it, drive it like you stole it type thing lol
  9. #9 Re: Race Car Losing Power
    Jul 2011
    oregon
    If your racing you should have a upgraded cooling system bigger radiator bigger fans lower temp t stat and get a big external trans cooler if your car temp is above 200 that also means the tranny seeing those temps too
  10. #10 Re: Race Car Losing Power
    May 2011
    We race on an asphalt track. We have made the mods for racing. Fan is on a swtich, bigger radiator, a c is out. I appreciate the feedback. It has been good stuff. We will try some of the stuff and I will give an update. If you think of something else, please share it!
  11. #11 Re: Race Car Losing Power
    Feb 2009
    flintnasty MI
    Quote Originally Posted by BuschLightBandit View Post
    Well, as far as tricking the sensor goes... I would suggest maybe you put the sensor on a toggle switch (dpst style switch), so that you will enable the temp sensor function until the motor gets up to the proper temp, then you throw the switch to a resistor (or voltage divider circut if its voltage driven) that locks the temp at 200 degrees or so.
    That resistor OHM reading (or the voltage divider design) can be read at the sensor when it is at the temperature you want.
  12. #12 Re: Race Car Losing Power
    Jul 2011
    oregon
    Is this water meth setup block ???
  13. #13 Re: Race Car Losing Power
    how big is the rad?
    There are easy/cheap drop in's that are 1.25" in core depth.
    Does it have ducting between the bumper and the rad?
    Thats pretty crucial to cooling.
  14. #14 Re: Race Car Losing Power
    May 2011
    I spoke with our driverand apparently we cut the t stat out. Will it help having it back in?
  15. #15 Re: Race Car Losing Power
    no.
    answer questions, there are reasons as to why we ask them.
  16. #16 Re: Race Car Losing Power
    Jul 2011
    oregon
    Yes you need a t stat witout one the coolant keeps flowing witout having enough time to get cooled down from the radiator I've built a couple of sbc for circle track racing and we always use a 160 t stat wit a small hole drilled in them
  17. #17 Re: Race Car Losing Power
    Feb 2009
    flintnasty MI
    Quote Originally Posted by pushrod4life View Post
    need is a strong word...
  18. #18 Re: Race Car Losing Power
    May 2011
    I was told we can't get a.bigger radiator. We could get an aluminium one, thats about it. I have no clue what a water meth block is. My guess is we don't have that. We run a stock car and use premium.
  19. #19 Re: Race Car Losing Power
    Feb 2009
    flintnasty MI
    Something like a 98 montecarlo (i forget what actually uses that radiator) uses like at least double size radiator over stock grand prix... and its a drop in FACTORY replacement... would take a keen eye by a track offical to catch it if it would violate any rules.
  20. #20 Re: Race Car Losing Power
    Do you have ducting?
  1. Losing power driving down the road
    By YeahRight in forum General Tech Discussion
    Last Post: 11-11-2011, 05:56 PM
  2. Well...looks like we're losing another dragstrip.
    By alkygto in forum The Rant Forum
    Last Post: 11-14-2010, 02:30 PM
  3. Losing power to wheels...
    By Deebo in forum General Tech Discussion
    Last Post: 05-01-2010, 03:06 PM
  4. losing power and stallin
    By jessica lavoy in forum General Tech Discussion
    Last Post: 03-12-2010, 02:36 PM
  5. 2 Race cars drag race
    By KawaFord in forum Off Topic Discussion
    Last Post: 09-06-2009, 02:11 AM
