Thread: HELP! Little piece of dipstick fell into oil tube/reservoir
Results 1 to 6 of 6
  1. #1 HELP! Little piece of dipstick fell into oil tube/reservoir
    Jun 2010
    winston-salem
    I was checking my oil because I have a little road trip tomorrow and when pulling out the dipstick somehow a little piece of the plastic finger grip part fell right in the oil tube. Will it cause any ill effects? I also cant put the dipstick all the way back in because of the piece lodged in there. any ideas on what to do?
  2. #2 Re: HELP! Little piece of dipstick fell into oil tube/reservoir
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    mine broke too but it held together enough so it only slid down to the end of the stick.. I wouldn't worry about it to much it will probabally just get ground up... its plastic. if its still in the tube just take it off and knock it out of there or replace the whole thing with a new tube and stick
  3. #3 Re: HELP! Little piece of dipstick fell into oil tube/reservoir
    Take a 13mm socket and wrench. Head to your local JY and find one fo the billions of cars where the tube is in the same position as yours. Undo the nut. Wiggle and pull. Soon it'll release and you'll bang your hand on something sharp. (Note: Bring band aids)
    Then pull yours out, and swap with the new one.
    $10 fix.
  4. #4 Re: HELP! Little piece of dipstick fell into oil tube/reservoir
    PA
    I wouldn't worry about it. Shouldn't cause any issues.
    But definitely replace the dipstick like Bill mentioned.
    2001 GSE
  5. #5 Re: HELP! Little piece of dipstick fell into oil tube/reservoir
    Jun 2010
    winston-salem
    Thanks everyone! The dipstick itself isnt broken, its just a little piece of the plastic thing that you put your finger through to pull the dipstick out. The comments really eased my mind because I thought it was something really bad! haha
  6. #6 Re: HELP! Little piece of dipstick fell into oil tube/reservoir
    Oct 2008
    Calgary, Alberta
    Take the dipstick tube off of your car as stated above and push out the broken piece of plastic from the bottom. Then bolt it back in place. Mine broke too and I replaced the platic head with one from the junkyard. Any gm car from that era is the same, pop the pin and all you need is the plastic piece. (You should have the tube sealed with a gasket, mine required a new plastic piece to seal.)
  1. 2000 GP SE Lock button broke/fell into Pass. Door
    By postalc38 in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2011, 11:21 PM
  2. Coolant Reservoir Tube?
    By Pagss in forum General Tech Discussion
    Last Post: 10-19-2010, 01:49 PM
  3. plastic trim on rear door fell off, please help
    By Wraith888 in forum Visual/Body Modifications
    Last Post: 08-11-2010, 09:02 AM
  4. Part of the resonator fell off, should i fix it?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 11:14 PM
  5. Modified Trans Dipstick tube from Intense...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-22-2008, 07:54 PM
