Thread: Symptoms like a clogged cat
Results 1 to 8 of 8
  1. #1 Symptoms like a clogged cat
    Jul 2011
    Springfield mo
    I have a 2002 grand prix gt with a 3.8 v6.
    A couple of weeks ago I changed the upper and lower intake gaskets and the water pump. Everything ran fine for a week and then I descided to take a trip go STL, and on the way back at first it idled fine but when I went to pass a car on the interstate it would rev up really high but I wouldnt speed up very much and the check engine light would flash. Well I didn't want to tow it so I drove it 400 miles like this and my mpg just kept dropping, and eventually it started idling high (2500 rpm)
    When it first started doing this I popped the hood and noticed the positive cable going to the alternator wasnt very tight and it was arching so I tightened it. Could this cause a bad ecu?
    I rented a code reader from autozone and came up with these codes P0101, P0102, P0122.
    I noticed something the other night the exhaust manifolds are glowing. I did some research and I think it could either be timing or the cat clogged. Could the timing being off cause it to idle high though?
    I replaced the idle air control valve and checked the throttle position sensor and when I unplug the MAF nothing changes
    Then I drilled a half inch hole in the exhaust before the cat and nothing changed
  2. #2 Re: Symptoms like a clogged cat
    Chicago, IL, USA
    You already have the answer P0101 = BAD MAF. When you unplugged the MAF and nothing changed, that was your clue to replace the MAF, which explains the MPG drop.
  3. #3 Re: Symptoms like a clogged cat
    Jul 2011
    Springfield mo
    Is there another way to test the MAF to be sure?
  4. #4 Re: Symptoms like a clogged cat
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    think the throttle body needs to be cleaned?? or maybe that vacuum line leaving the tb may be clogged up
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: Symptoms like a clogged cat
    Jul 2011
    Springfield mo
    Quote Originally Posted by christophero1973 View Post
    I thought of you unplug it, it goes to a default setting?
  6. #6 Re: Symptoms like a clogged cat
    Jul 2011
    Springfield mo
    Quote Originally Posted by GTPSHAWTY View Post
    I dont think it needs cleaned I'll check the vacuum line though
  7. #7 Re: Symptoms like a clogged cat
    Jul 2011
    Springfield mo
    I checked the vacuum line it's clear
  8. #8 Re: Symptoms like a clogged cat
    Jul 2011
    Springfield mo
    Any other ideas? What can the PVC cause?
  1. Possible clogged cat
    By black plague815 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 11:02 AM
  2. Cat clogged
    By wingman65 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-31-2011, 07:26 AM
  3. figuring out if your cat is clogged
    By imdaman3 in forum How To Write-Ups/Tech Tips
    Last Post: 08-20-2010, 04:52 PM
  4. Are these symptoms of a bad hub assembly?
    By nawarkk in forum General Tech Discussion
    Last Post: 02-18-2010, 09:28 PM
  5. Clogged cat, bad o2?
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 01:38 PM
