Thread: Crazy Taz and his wire tuck.
Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 384
  1. #41 Re: Crazy Taz and his wire tuck.
    Most of the glue on these cars is seam sealer which has spotwelds under it, tho I have seen plently places in the front wheel wells for example where more seam sealer should have been used and some cars start to rust around the top of the strut towers and the firewall. I'd love to see a great wire tuck done. Best I've ever seen was the one Kuntzie did to clean up his bagged turbo car. That build from the Bonnie site it kick ass too. Good Luck Taz and Im certinaly looking forward to the results!
  2. #42 Re: Crazy Taz and his wire tuck.
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    well the only stuff I'm moving to the trunk is
    -battery
    -coolant bottle
    -fuse box
    -pcm
    -and maybe the washer fluid maybe but I doubt it
  3. #43 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    These cars are setup much easier to do a tuck on than that bonny, it's all a matter of time and a few parts here and there but I think I can do it all for around 300 and that includes the fatmat I'm putting down on the inside after moving all the stuff.
  4. #44 Re: Crazy Taz and his wire tuck.
    Quote Originally Posted by Taz Magester View Post
    -battery
    -coolant bottle
    -fuse box
    -pcm
    You are nuts.
  5. #45 Re: Crazy Taz and his wire tuck.
    Should search some honda wire tucks and shaved bays, I dont think Id move the coolant bottle that far back because you'd have to make sure the line could get the fluid that far back. I'd try find something like an alum oil catch can or something used for the coolant. Just try find a small alum can and hide it in the passenger side in front of the wheel well.
  6. #46 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    I was going to use this if its hidden
  7. #47 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    You are nuts.
    It say's "Crazy Taz" in the thread title
  8. #48 Re: Crazy Taz and his wire tuck.
    Mike is beyond nuts. You are way past crazy after what you pm'd me this morning about the side cover on the trans.
  9. #49 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    hey its starting to shine up Just 4-6 more hours and then i can move to 280grit for a day or 2 and so on and so on
  10. #50 Re: Crazy Taz and his wire tuck.
    Florida
    just an FYI i had a guy i worked with that was doing an MR2 build. he used fuel/ brake line to run his wires!
    when i do my swap i dont think im going this all out, but i want to hide as much as i can. i just dont like the birds nest of wires these cars have.
  11. #51 Re: Crazy Taz and his wire tuck.
    the car runs on 12VDC. the entire wire harness should be blue with labels on both ends.
  12. #52 Re: Crazy Taz and his wire tuck.
    Florida
    well yes and no... the car does run off of 12v but many of the sensors run off of 5v dc.
  13. #53 Re: Crazy Taz and his wire tuck.
  14. #54 Re: Crazy Taz and his wire tuck.
    Grand Island, Nebraska
    After doing the top swap I really need to do this...the fuel lines need redone the most.
  15. #55 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    Quote Originally Posted by JoRoW99 View Post
    I think I might wait on tucking some of the stuff untill I do the top swap so I don't have to redo stuff
  16. #56 Re: Crazy Taz and his wire tuck.
    Yea good idea...because the harness gets in the way. If you shortened it or anything and made it harder to move it would get frustrating real quick.
  17. #57 Re: Crazy Taz and his wire tuck.
    Soldering is easy...
  18. #58 Re: Crazy Taz and his wire tuck.
    Ok I just got a good idea for ya taz. Since you are moving everything to the trunk, take out the OnStar box thing. There will also be a LOT of colored wires leading to it that are dead weight. If you take those out you can reduce the weight in your car by 10-20 lbs and have free colored wire
  19. #59 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    Ahh kk
  20. #60 Re: Crazy Taz and his wire tuck.
    SE Level Member jpe's Avatar
    Jul 2011
    WI
    this project is going to look great just be sure to get lots of pics for us along the way. i cant wait to see it.
    08 gt mustang
    87 t top resto in progress
    01 gt grand prix (sold)
    01 se grand prix
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. my wire tuck!
    By kuntzie in forum Visual/Body Modifications
    Last Post: 06-07-2011, 07:36 AM
  3. Help me my car is going crazy!!
    By csssaint12 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2011, 12:53 PM
  4. Wire tuck
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 06-05-2009, 02:37 AM
  5. crazy car need some help
    By KingOfTheSouth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 12:29 AM
