Just hit the fire with the body of the extinguisher, its cheaper that way.
any gas station has jet fuel. its called diesel though
no...I even bought extra wire this time... but sure enough I came up short again... with only 8 wires left that need extended... as you all can tell I didn't plan this thing out very well...
To anyone ever considering doing this, I suggest ahead of time you order atleast 500 feet of 20 awg 250 feet of 18 awg 50 feet of 14, and about 25 feet of 10 awg then you also need atleast 15 feet of some big old wire to run for the battery and that 15 feet alone will set you back atleast 30 bucks 100+ if you get some legit battery wire. You also need a good 5-10 feet of number 2 wire. About 100 feet of heat shrink Idk exactly how much but it's a lot trust me. then you add in little things like ends for the battery line fuses/fuse holders, maybe a cut-off switch...
My point being if you look at this thread you can tell I wasn't prepared for this at all lol. If I had been the process would be going much smoother and I would probablly have had it up and running again then taken apart again to do the other side. So if your as crazy as me atlest gather your supplies ahead of time lol
One I wouldn't order it from a chinese retailer unless I was trying to set my car on fire. Chinese metal is just INFERIOR It just is... plain in simple, thats why I never worry about a world war with china at this point they can't produce a quality Item. No offense to china.
And two why would you say something like "I hope you can get it started again!'' are you implying that my car might never run again?... just say good luck lol
It'll esplode
Blue heat shrink?!?!? no wai
^^Your car has pimples.
Pop 'em.
Also, the 3800 Series II needs to be red...and no Comp Cams decals.
