bought a very clean 02 gp gt, and the under hood relay number 11 was fried, burnt, toasted, blown ,.well you get it ..... rewired a new under hood fuse panel and replaced all of the burnt wire .... and the relay will just buzz when the key is turned on. the fuel pump will not cycle either, but when you remove relay 11 the fuel pump does cycle but because i pulled the relay the ign is not on..... any thoughts?? heres what i have tried had another pcm and does the exact same thing....hum....... iam able to start the car if i jumper 2 of the 4 prongs in the under hood fuse box 11 location and then run a hot wire to a leg of the fuel pump ......and then today i replaced the ign switch
