I have a 96 v6 camaro series 2 i just changed plugs wire pcv valve fuel filter and hvac check valve and now the thing is missing...Could the pcv valve plate leak and cause this? Any other ideas are MORE than welcome!!![]()
No, but a crossed plug wire will. Either that or one is loose. Double check the firing order and your wires.
I wouldn't think a vac leak from the PCV plate would cause a miss. It would run wierd but not miss I would think.
check to see if one of the new plugs is cracked or broken.
Can you figure out which plug has the misfire??
If you can swap the coils around and see if the miss follows the coil. If it does, that coil is bad.
vac leaks?
That looks kinda like a fuel pressure regulator to me...
