Thread: After tune up blues
Results 1 to 10 of 10
  1. #1 After tune up blues
    SE Level Member Austin2000SE's Avatar
    Sioux falls SD
    I have a 96 v6 camaro series 2 i just changed plugs wire pcv valve fuel filter and hvac check valve and now the thing is missing...Could the pcv valve plate leak and cause this? Any other ideas are MORE than welcome!!
  2. #2 Re: After tune up blues
    St. Louis
    No, but a crossed plug wire will. Either that or one is loose. Double check the firing order and your wires.
    I wouldn't think a vac leak from the PCV plate would cause a miss. It would run wierd but not miss I would think.
  3. #3 Re: After tune up blues
    Sioux falls SD
    Checked all of the wires all in order correctly... unhooked the battery also to reset pcm nothing.
  4. #4 Re: After tune up blues
    check to see if one of the new plugs is cracked or broken.
    Can you figure out which plug has the misfire??
    If you can swap the coils around and see if the miss follows the coil. If it does, that coil is bad.
  5. #5 Re: After tune up blues
    vac leaks?
  6. #6 Re: After tune up blues
    Sioux falls SD
    Checked all once again but found a vac line from something on the fuel rail? where shld this go?
  7. #7 Re: After tune up blues
    Omaha, NE
    That looks kinda like a fuel pressure regulator to me...
  8. #8 Re: After tune up blues
    Sioux falls SD
    the fuel presure regulator is on the other side this also has a line going to the throttle body
  9. #9 Re: After tune up blues
    Pennsylvania
    Oddly enough, I think that might actually just be a vent.
    Edit: Oh hey, EVAP Canister Switch.
  10. #10 Re: After tune up blues
    Sioux falls SD
    Im gonna try swapping a coil pack out and see if that fixes anything...
  1. Anyone here into the blues?
    By Pairsnpaint in forum Off Topic Discussion
    Last Post: 05-13-2011, 02:28 PM
  2. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  3. PRJ Tune
    By 2001GTP in forum PCM Tuning
    Last Post: 04-15-2010, 08:06 AM
  4. where to get a tune?
    By JayGTP02 in forum General Tech Discussion
    Last Post: 09-06-2009, 10:52 AM
  5. gt blues
    By MARKS99 in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 10:56 AM
