Thread: Thermostat
Results 1 to 3 of 3
  1. #1 Thermostat
    New Jersey
    Whats involved on changing the t-stat on an 06 base model?
    I'm assuming drain a gallon out of the system, pull the plastic cover off of the engine and the t-stat housing should be right there.
    I see most places list a single gasket for it. Is this for the t-stat or for the housing?
    I just want to get everything I need before I dig in. I did my coolant around a year ago and now I'm sorry I didn't do the t-stat.
    I'm looking at a Stant superstat series as I like the idea of a more consistent temperature if they actually work.
  2. #2 Re: Thermostat
    dont even drain any coolant. just refill what you spill.
    the gasket comes on the thermostat, it's the rubber o-ring.
  3. #3 Re: Thermostat
    dont forget to bleed the cooling system when done.
    Also just get a stock replacement 195ยบ thermo.
  1. Thermostat?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-08-2011, 08:33 PM
  2. Thermostat
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2011, 07:02 AM
  3. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  4. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
  5. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
