Thread: powertrain issue has me stumped
Results 1 to 11 of 11
  1. #1 powertrain issue has me stumped
    Nov 2012
    NY
    first off, hello, I'm the new guy ! I bought my wife a 2006 Grand Prix a few months ago with about 115k on it, body is in great shape it looks like the car was well taken care of. first symptom was the remote start would turn over briefly then not start and the lights flash. so I put plugs and wires on it (PITA) And that didn't help. So i said it's probly the battery, and as it's gotten colder out ive noticed sometimes the engine wont turn over on the first attempt, and it wont fire up if it's only turned over breifly. all that makes me think battery until tonight, she was stranded beside the road so i came from work and checked it out. she said she was accelerating from a stop and the car started bucking every time she pressed the pedal and the Tach was going from 0 to redline irradically but she couldn't hear the engine actually revving. I suspected transmission given the milage. the fluid is brown and smells like play-doh/menstration mix but the level is right on the money so it isn't leaking or burning off any. So i drove it and it was fine, Could not duplicate. My immediate thought was torque converter shudder, but that wouldn't just go away. My next thought is that the Tach bouncing is some kind of telltale diag for something, fuel pump maybe. No CEL which makes things really fun. I know a trans service would only help things but i don't want to drop 80 on fluid and filter, then have to replace a trans. I am a technician, but I am a Chrysler tech, so I really don't see GM ever.
  2. #2 Re: powertrain issue has me stumped
    St. Louis
    Start by cleaning the MAF w/ the appropriate cleaner. May also want to remove the throttle body and clean it till it shines. The TB's cause all sorts of strange issues on the 04+ cars when they are dirty. Make sure you clean the entire thing, not just spray the front of the butterfly. Being DBW, the TPS could be bad as well.
    Beyond that it could be a crankshaft position sensor. Those often throw no codes when they start to die.
  3. #3 Re: powertrain issue has me stumped
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    I can tell you from personal experience that the gauges start to flip out and begin to twitch when the battery is beginning to fail. It's happened to me twice in the 8 years I've owned the car.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  4. #4 Re: powertrain issue has me stumped
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Agreed with what the others have said. Clean the throttle body (it's easy), clean the MAF with the right cleaner, and get the battery/alt tested. The battery is right on the edge of that 7 year life span. Also, sounds like the trans fluid really needs a change. Just don't get a power flush. That killed the tranny on my old car. If you're handy, do a pan drop and replace the filter yourself. Dropping the pan on this car gets most of the fluid (almost 8 quarts for me), but it's better than driving with crap burnt fluid. I think the GM official procedure is to drop the pan three times over a certain number of miles. I too the time to add a drain plug to mine so I can just drain the fluid next spring.
  5. #5 Re: powertrain issue has me stumped
    Nov 2012
    NY
    ya i was planning on a trans fluid change but it's hard to get an open hoist after work because it's 4wd season up here and we have alot of transmission jobs going on so they generally stay on the lift for 2 days. Is there anything better than the delco battery? cleaning the maf today and i'm pretty sure the alternator is good, it charges at about 14.5v but overnight with no loads the batt voltage drops to 11.3v range
  6. #6 Re: powertrain issue has me stumped
    ive got a interstate battery for the last 2 years, no problems so far.
  7. #7 Re: powertrain issue has me stumped
    Eau Claire, WI
    I bought a Road Runner. I had to adapt to side post terminals, but I saved $60 by ditching the glass mat Delco battery. And I ended up with 850 CCA, 130 more amps than my stock battery.
  8. #8 Re: powertrain issue has me stumped
    Nov 2012
    NY
    i cleaned the maf annd throttle body, although the maf looked fine. throttle body was disgusting. now to find a decent battery.
  9. #9 Re: powertrain issue has me stumped
    Kansas
    Quote Originally Posted by TRamsdell View Post
    Bahahaha quote of the day!
    Filter and fluid can be done very easily... just jack it up and put jackstand under it.
  10. #10 Re: powertrain issue has me stumped
    Nov 2012
    NY
    Quote Originally Posted by NegativeOne13 View Post
    sir, i am not doing it in my driveway, i will drive it to work and put it up after hours and use all my overpriced tools that get **** done faster, but yes that's the exact description of the fluid, i'm pretty sure it's described that way in the service manual:"When transmission oil becomes brown and smells like play-doh/menstration, service is required."
  11. #11 Re: powertrain issue has me stumped
    Nov 2012
    NY
    quick update. yesterday after a bad day at work, my wife calls me and says her car has no power steering. I immediately said don't go anywhere! so i got to her and opened the hood AHA! the belt was knocked off, so i stasrted wiggling things, water pump pulley was trashed. so I went out and got a battery and the water pump and associated crap. did the repairs and flushed the cooling system. so, i will keep posting if the chuggaluggin happens again
  1. Stumped on cooling fan issue
    By indy99gpgt in forum General Tech Discussion
    Last Post: 07-01-2012, 10:57 AM
  2. Overheating issue - absolutely stumped (Done almost everything)
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2012, 03:26 AM
  3. powertrain vibration
    By 00pontiac1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2008, 10:07 PM
  4. Is it worth it Powertrain Swap
    By WindsorGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-19-2008, 08:59 PM
