Thread: Split ratio rocker question
Results 1 to 16 of 16
  1. #1 Split ratio rocker question
    SE Level Member zerolimitsgt's Avatar
    Apr 2009
    Cortland, Ohio
    If I install split ratio rockers in my L36, is it necessary to upgrade the valve springs as well or would it be ok to leave the stock springs in? Will not changing springs result in valve float?
  2. #2 Re: Split ratio rocker question
    I'd never install anything with a higher rocker ratio on stock springs if it is more than 1.84:1. Also...keep your shift points at 6K or lower.
    L36 cars tend to like ZZP ER Rockers anyhow...and you'll want some flow mods and a tune to get the most out of them.
  3. #3 Re: Split ratio rocker question
    Banned
    Apr 2011
    wv
    i used my stock springs and havent had any problems. i did a few exhaust mods first to get the most out of it.
  4. #4 Re: Split ratio rocker question
    Quote Originally Posted by L36pro View Post
    Ever had it on a dyno to see if your having signs of valve float?
    I bet not.
  5. #5 Re: Split ratio rocker question
    Apr 2009
    Cortland, Ohio
    How long have you been running them with stock springs? I have headers and a GMPP exhaust so got exhaust mods covered. Is there another way to tell if you're getting valve float besides having it dynoed?
  6. #6 Re: Split ratio rocker question
    loss of power?
    Banned
    Apr 2011
    wv
    been running them with stock springs since i did the mod. 6100 rpm shift point with hv3 too. if i could do it again, i would ditch the er's and just go with the hv3. with my current mods, the ER's drain the bottom end
    nope. i live in bfe. no dyno for 100 miles and no track for 150
  8. #8 Re: Split ratio rocker question
    ER's do not lose bottom end power. you're still on the stock cam meaning all you've done was increase overall lift. you did not change the actual powerband. therefore, you are crazy.
  9. #9 Re: Split ratio rocker question
    Apr 2009
    Cortland, Ohio
    Idk whether I should try the rockers without the springs or not
  10. #10 Re: Split ratio rocker question
    Banned
    Apr 2011
    wv
    get some springs. 90 pounders. im starting to regret not getting them
  11. #11 Re: Split ratio rocker question
  12. #12 Re: Split ratio rocker question
    Dec 2008
    Lawndale, CA
    I did not replace the springs on mine. I installed the ER rockers with very low miles. I also don't go to the track. I just added some mods to make it a little nicer daily driver. If I did go to the track then for sure I would replace the springs.
  13. #13 Re: Split ratio rocker question
    Banned
    Apr 2011
    wv
    ive heard that some people are having problems with the ls1 springs. i would skip the L76 and go with some tight zzp springs.
  14. #14 Re: Split ratio rocker question
    ZZP Springs huh?
    Link?
    Because ZZP doesn't make valve springs guy. Care to elaborate why L76 springs aren't good enough? Because they are just fine for a rocker car.
  15. #15 Re: Split ratio rocker question
    and ZZP doesn't use all LSx springs and LSx valves.
  16. #16 Re: Split ratio rocker question
    Apr 2009
    Cortland, Ohio
    I only run my car at the track like 4-5 times maybe, if that a year and i won't be driving it daily this year.
  1. Rocker ratio
    By gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:29 PM
  2. Larger Cam With Larger Rocker Ratio's?
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2009, 02:29 PM
  3. rocker question
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 05:57 PM
  4. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
