Thread: 4" outside diameter
Results 1 to 8 of 8
  1. #1 4" outside diameter
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    i need help trying to find a piece about 1 ft long...cant find any anywhere!!
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: 4" outside diameter
    Oklahoma
    Im assuming you are talking about intake tubing? If so, check the local hardware stores, plumbing section. I dont know if you can get it there or not, but look for ABS pipe. I can get it locally in about 5' sections maybe for $6 -7 or so, somewhere in there. Yeah, its more than you need but you'd have it.
  3. #3 Re: 4" outside diameter
    Barksdale AFB, LA
    2009 Subaru Impreza WRX STI
  4. #4 Re: 4" outside diameter
    Oklahoma
    Well crap, I didnt know about that.
  5. #5 Re: 4" outside diameter
    Fayetteville, NY
    thanks for the info...whats your take on the intense tubing?
  6. #6 Re: 4" outside diameter
    Barksdale AFB, LA
    Quote Originally Posted by GP2003GT View Post
    Simple, but effective. Maybe not the prettiest.
  7. #7 Re: 4" outside diameter
    Fayetteville, NY
    yeah well maybe you can make it look nice...lol
  8. #8 Re: 4" outside diameter
    Fayetteville, NY
    well i ordered that piece, thanks for the info i looked all over the place from local hardware stores, and believe me i was really frustrated!
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Radiator Hose Diameter
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 05-20-2008, 03:01 PM
  3. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
  4. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
