Thread: Coolant Light
Results 1 to 6 of 6
  1. #1 Coolant Light
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    A few weeks ago my "low coolant" light came on and I put some more coolant in after checking levels. I think whatever sensor that measures the level is broken because the light goes on and off regularly. It will stay on for about 10 mins and then go off for a little bit and then come back on agian. and it doesnt matter if im moving or not, i've had it turn off and on within the lenght of a red light. Am i right to replace the sensor and does anyone know where it is?
  2. #2 Re: Coolant Light
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    My car does EXACTLY the same thing. I dont know how to fix it. It used to stay on all the time so I put a new sensor in. Now that it has a brand new one it does exactly what you are describing. If you fix it tell me what you did lol.
  3. #3 Re: Coolant Light
    sometimes it gets dirty.
    then it doesnt work properly.
    its below the rad cap.
  4. #4 Re: Coolant Light
    Raleigh, NC
    @ agentlongwood,
    the sensor was pretty dirty so i cleaned it, but it didnt help.
    looks like we're stuck with this light a little longer
  5. #5 Re: Coolant Light
    HUDSON
    Remove passanger side headlight assembly, reach in and unplugg sensor, light will then be off all the time. Or buy a new sensor and install.
  6. #6 Re: Coolant Light
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Bakerdd View Post
    @ agentlongwood,
    If cleaning it did not help then you need a new one. Dexcool gunks up the sensor.
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Low coolant light?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2009, 01:13 PM
  4. coolant light
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 03:18 PM
  5. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
