Thread: Oil Level Light problem likely the sending unit?
Results 1 to 3 of 3
  1. #1 Oil Level Light problem likely the sending unit?
    SE Level Member pur3vil's Avatar
    Bismarck, ND
    Just wanted to throw this out there before I go and replace the level sensor. When the car sits for anything over an hour, maybe two, the oil level light will come on... if I restart the car it stays off. Therefore I turn the key on, wait for it to come on, turn it off and back on and I'm golden.. is this a sensor issue? what does it trigger? BCM? PCM? is a Batt pull in order to resolve it?
    I really don't want to replace it right now, I've got a laundry list of things to do when it dries up outside as it is including sways (front and rear) , LF halfshaft, tires, alignment ( both waiting on sways and shaft, which is again waiting on weather, currently it's sleet/snow/raining 1-4 inches total accumulation for the next 36 hours... )
    If it's a batt pull I'll do it when I get home from the oil change, if it's a sensor I'll buy it and put it with the rest of crap to do when I can lay on the ground...
    arg....
    Oh and where's the best place to pick up an ignition switch?
    (Project) 87 Conquest LE 5sp | 89 Conquest TSI 5sp (Donor)
    91 6000 LE 190k | 92 Astro "W" EXT AWD 398k | 03 Sebring LX 98k
    93 GPLE 298k | 95 GTP 215k | 97 GPGT 169k
    98 Javelin 379 FS w/ 78 Merc 115 ( The Toy )
  2. #2 Re: Oil Level Light problem likely the sending unit?
    This is simply a light. If you know it's not a problem and the oil stays up to level etc w/o issue. Crawl under and disconnect the plug, tape it up until you are doing an oil change and want to swap.
    BTW, I have a pile.. pay shipping and I'll send you one for cost of shipping.
  3. #3 Re: Oil Level Light problem likely the sending unit?
    Bismarck, ND
    Sold sir, Shipping to 58504 and a paypal addy.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Oil Sending Unit
    By TeeWX in forum General Tech Discussion
    Last Post: 03-20-2010, 12:31 PM
  3. where to put oil psi sending unit???
    By ERDGT1 in forum General Tech Discussion
    Last Post: 02-01-2010, 09:30 PM
