Thread: coolant elbow leak again
Results 1 to 19 of 19
  1. #1 coolant elbow leak again
    Nov 2010
    Nashville TN
    Three month after replacement during LIM work, This elbow leaked again!
    Is there any tips for correctly seating this dreaded elbow to the engine block?
    By the way, the replacement elbows I used are from autozone help section, Dorman brand. I heard someone complained that these elbow is slightly thinner than the OEM parts, hence causing the leak. Anyone can comment on this?
    Thanks.
  2. #2 Re: coolant elbow leak again
    St. Louis
    I've used those before w/o issue, but I always put a small bead of RTV on it (on the edge in front of the o-ring) before installing it to make up for any imperfections in the LIM or tensioner. Never had one leak doing it that way. I use the gray GM sealant, but suppose the plain black RTV would work as well.
  3. #3 Re: coolant elbow leak again
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I've had mixed experiences with the oreiley,auto zone brand. I'd get the gm ones, not that much more
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  4. #4 Re: coolant elbow leak again
    SE Level Member brianwalter86's Avatar
    Apr 2011
    michigan
    How much are those coolant elbows? I might need some too. Did you end up stopping the leak? Or you buy new ones?
    Thanks
    Brian
  5. #5 Re: coolant elbow leak again
    Banned
    Apr 2011
    wv
    this happened to me with my bonneville. the orange gaskets are heat activated and flatten out. when this happens they leak. pull your elbows back out and put some black o rings in place and the leak will stop. in fact, i would invest in a quality set of o-rings.
  6. #6 Re: coolant elbow leak again
    The o-rings aren't orange though.
    At least none of the ones I've seen in the past three years have been.
  7. #7 Re: coolant elbow leak again
    Banned
    Apr 2011
    wv
    the ones you buy at the auto store do indeed have orange and purple o-rings. any color other than black are heat activated o-rings. go to autozone and look at them.
  8. #8 Re: coolant elbow leak again
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Sorry Matt, but he's right...One orange one purple
    I actually double O-ring'ed them to prevent a leak. My original black ones weren't too bad so I saved them, rolled them further down the elbow so they were out of the way when I was installing, then once I got the elbows seated and in place and everything bolted back down I took a small screwdriver and pushed the black one snug in there as a second line of protection. Probably does nothing, but I don't really care!
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  9. #9 Re: coolant elbow leak again
    Banned
    Apr 2011
    wv
    replacing them with black fixed my 04 bonneville.
  10. #10 Re: coolant elbow leak again
    GT Level Member clevelandfan's Avatar
    ohio
    if u get them from anywhere it should work to tell the truth. make sure u put a good amount of rtv on it, and make sure it is set all the way in. i kno it can be kinda hard to tell sometimes
    97' Grand Prix. Blurring the lines between SE, and GT
  11. #11 Re: coolant elbow leak again
    I use the dormans all the time.
    I've found that if you don't wiggle the upper elbow as you tighten the alt bracket/tensioner you can pinch the elbow and cause it over time to become more of a 45 degree angle than a 90. This will then leak.
    Clean both holes with steel wool. Lube the rings with something and wiggle as you tighten the bolts.
  12. #12 Re: coolant elbow leak again
    Your sig works for this.
  13. #13 Re: coolant elbow leak again
    True
  14. #14 Re: coolant elbow leak again
    Banned
    Apr 2011
    wv
    lol
  15. #15 Re: coolant elbow leak again
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    not sure what brand elbows came with my new duralast tensioner, but they crapped out after about 2 years (and now the pulley on it is getting loud). new gm ones from the dealership was a bit under $20 for the pair
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  16. #16 Re: coolant elbow leak again
  17. #17 Re: coolant elbow leak again
    Banned
    Apr 2011
    wv
    i think it depends on how hot your engine runs as well. my bonneville runs really hot and they crapped out after 60k.
    my gp gt runs really cold and they were still fine when i replaced them at 210k
  18. #18 Re: coolant elbow leak again
    It's not actually temp. It's pressure. If the tensioner is tightened and the top elbow doesn't wiggle freely..it's gonna become less than a 90* angle soon enough. 160-180F is enough to allow it to bend.
    If it's wigglin free...life should be good... just like non-restrictive underwear
  19. #19 Re: coolant elbow leak again
    Banned
    Apr 2011
    wv
    on my bonneville they actually crumbled apart at the gap where the o-ring sits. it wasnt an o-ring failure, but the elbow itself disintegrated.
  1. Coolant elbow leak...is it fixable???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2010, 11:29 PM
  2. new coolant elbow loose ?
    By rustang92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2010, 09:37 PM
  3. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  4. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
  5. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
