Now that i've got the engine out, i plan to:
1) Replace powersteering pump
2) replace coolant hoses
3) replace spark plugs and plug cables
4) Fix tranny and replace torque converter
5) Replace serpentine belt
6) Replace engine oil pan gasket (I think there was a bulletin about this a few years ago)
7) ??
Is there any other maintenance stuff I should be doing?
I want to do the least amount of work possible on the engine, since it was pretty good when I removed it, and I want to do as much maintenance as possible without spending a lot of cash. Also, if I can do any cheap mods (like less than $100-$200) if it will help with MPG, I will probably pursue it. The car is completely stock right now.
Any suggestions are appreciated.
