Thread: Coolant leak spot found whats the fix
Results 1 to 8 of 8
  1. #1 Coolant leak spot found whats the fix
    Michigan
    Rented a coolant presurizing tool from Autozone, found the leak. Here is a pic and video... so what is most likely wrong and whats the fix?
    View My Video
  2. #2 Re: Coolant leak spot found whats the fix
    looks like the lower intake manifold gasket went out on you.
  3. #3 Re: Coolant leak spot found whats the fix
    St. Louis
    You mean the UPPER Intake Gasket. I had a leak there when my UIM warped. Leaked right around the coolant passages and dripped down towards the thermostat neck. You might get it to stop by checking the torque on the 2 bolts around that area on the UIM and tightening them down some, but I doubt it.
    Fixed mine by replacing the UIM itself and UIM gasket.
    You may get lucky and just be able to pull the UIM and replace the gasket itself, but beware that the plastic on that UIM is probably getting weak by now and when you go to re-install it may crack around the bolts, or may not seal again as it gets erroded by heat inside. Had 2 stock ones do that before I replaced it with an updated one. Just warning you in case you still get a leak after just a gasket replacement. I don't know how many times you want to pull the fuel rail, injectors, and all the other goodies just to dig the UIM out, but 3 times was enough for me, lol....
    Jay
  4. #4 Re: Coolant leak spot found whats the fix
    Michigan
    I had the UIM replaced about 18 months ago. Hopefully I don't have to buy another one.
  5. #5 Re: Coolant leak spot found whats the fix
    Michigan
    Pic of the entire engine compartment. Leak location circled.
  6. #6 Re: Coolant leak spot found whats the fix
    St. Louis
    When the UIM was replaced, was the gasket reused?
    Try checking the torque on the UIM. The bolts may be loose. Especially check the 2 long ones that you see on either side near the TB.
    If that doesn't help then you are looking at just replacing the gasket. If you do this yourself keep an eye on the fuel injector orings when you remove the rail, as they may be split and leak upon reinstall.
  7. #7 Re: Coolant leak spot found whats the fix
    Virginia
    we have the same prob.............................same spot
    WHATS THE EASYIEST WAY TO GET THE INJECTOR RAIL OFF TO GET IT OUT THE WAY
  8. #8 Re: Coolant leak spot found whats the fix
    READ YOUR POST, WHERE YOU ASKED THAT VERY SAME QUESTION
  1. Coolant Leak
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 10:06 AM
  2. Coolant leak?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 01:59 PM
  3. Exhaust leak, Whats the probable fix?
    By GPGT99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2009, 01:01 AM
  4. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
  5. Finally found my vac leak... NOW WHAT??
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 02:32 PM
