Thread: rebuild ac compressor..??
Results 1 to 10 of 10
  1. #1 rebuild ac compressor..??
    GTP Level Member
    springfield IL
    have a 2000 GP GT(3.8). this summer got my ac back working as i hit a deer back in 07. car sat for awhile(2yrs..LOL) pieced it back together for a 2nd car. the ac didnt work. condenser was bad, replaced it ac worked great this summer. also changed a blend door motor and added more freon
    noticed the air wasnt getn cold as it should...my compressor makes a metal jingle/grinding sound..?? thinkn the clutch is bad, but still works... also may have a small leak in it cause i had to add freon with in a month..it was a HOT month.. LOL
    my question is, will is be worth having it rebuilt or buying a used one from morad..????
    THANKX
  2. #2 Re: rebuild ac compressor..??
    St. Louis
    That sounds like the clutch bearing is going out. Recently replaced the A/C comp. on a Bonneville due to this. The clutch assembly was half the cost of a NEW (not reman.) compressor, so we just decided to replace the whole thing.
    Either way, don't forget to replace any o-rings and the orifice tube while you're in there.
  3. #3 Re: rebuild ac compressor..??
    GTP Level Member
    springfield IL
    ^^ the sound is only when the i have the ac off.. soon as i turn the ac on the comp kicks on and the sound goes away...
    i heard from 2 GREAT mechs that some brands of ac comps dont get the air cold as the oem does... thats what i was thinkn of just repairing it or getn a used oem..
  4. #4 Re: rebuild ac compressor..??
    St. Louis
    That's what the Bonne did. Although I suspect that the noise is just less prevalent when it's engaged, not completely gone.
    Don't know about the aftermarket units, as we used an OEM Delco unit. Quiet as can be and the vent temp stabilized at 38* in Park/Idle at full oper. temp with the outside temp being 85*. Not too bad.
  5. #5 Re: rebuild ac compressor..??
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    I had to replace the whole compressor on my 06 didnt sell just the clutch. Anyway I bought mine used off a wrecked one on ebay for like $50 compare to the $250 sumthing new. If I knew about Morad then I woulda went through them. Anyway just go used there too steep new. Just my .0002 cents
  6. #6 Re: rebuild ac compressor..??
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    coming from a truck mechanic i would just replace the compressor. you said that it sat for 2 years. i would also replaced the dryer to. have the system charged by the pros with a real A/C machine. our trucks at work have 2 A/C systems on the. get alot of experience on them in the summer
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  7. #7 Re: rebuild ac compressor..??
    GTP Level Member
    springfield IL
    Where is the dryer at???
  8. #8 Re: rebuild ac compressor..??
    St. Louis
    That's the aluminum cylinder that is about the size of a 24oz beer, should be near/under the airbox area. Has 2 lines that run into it from the compressor. Some people may call it an accumulator. Heard it both ways.
  9. #9 Re: rebuild ac compressor..??
    GTP Level Member
    springfield IL
    Quote Originally Posted by FordMan77 View Post
    i noticed this is made by a brand called 4-seasons.. was told to stay away form there ac products.. could i just get a used one?? if not whats a good brand??
  10. #10 Re: rebuild ac compressor..??
    Feb 2010
    indianapolis
    no you have to get a new one. they have desiccant in them like the little packs in the beef jerky packs. when it gets exposed to air it sucks the moisture out of the air and the desiccant no worky anymore. just have to replace with new. get one from carquest or napa. stock replacements.
  1. AC Compressor Kit
    By PrissiePantsGT in forum General Tech Discussion
    Last Post: 08-11-2010, 10:24 AM
  2. i need a new A/C compressor
    By foursixer in forum General Tech Discussion
    Last Post: 06-25-2010, 10:52 AM
  3. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  4. AC Compressor
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2009, 02:56 PM
