My Grand Prix GT has been acting up recently. It is getting extremely horrible gas milage, I figured it to be about 8 MPG in town! i have changed the air filter, spark plugs, fuel relay, and a coil pack. next on my list is fuel filter and plug wires. Now when I did the plugs i pulled out autolite double plantinums(i was so pissed seeing cheap crap plugs in it) and replaced them with E3's. Replacing the air filter i found the one in it to be bent, with a few pleets bent up and part of the gasket on the edge gone! I also cleaned the throttle body and added some fuel cleaner(Sea Foam) to a full tank of gas. Ok so it helped a little bit, I am getting about 12 MPG now, but my car is still Idling very strangely. It will idle at about 900 but loses RMS and the engine revs back up my itself. There are also times where I am stopped and the car will rev up and try to take off by itself. I'm thinking it may be the throttle control sensor, but could also have to do with the fact the plug wires on it now are crappy autolites. any suggestions on which step i should take next to get my car to where it should be running and idling properly? Thank you in advance.
