OK. I've read a few that are close to my problem, but I will explain my problem. I have a 2005 GT 3.8L Nat. Asp. The engine will hesitate(chug) while I am driving. This is an intermittant problem. It may only happen once a week, once a month, there is no rhyme nor reason for when it acts up. It will do the chugging at low speed, feels like I have a boat anchor attached. It also seems to shift hard when this is happening. When I get up to highway speeds, I will be running along well and all the sudden it will start hesitating, I will lose RPMs and speed. So I push the gas to get back up to speed, then it may or may not start to gain speed and R's like it is coming out of the problem. I have had the dealer repair this under warranty multiple times. They have replaced the MAF twice and reprogrammed the PCM three times. The last time they changed the MAF they said it was bad from the K&N filter I had on it. I don't believe it was the MAF either time because it will do it again after the MAF is replaced. I have shut it off while this is happening(put it in neutral and coast, shut it off for a 10-15 seconds and restart) and it seems to clear it up. Any help would be greatly appreciated.
