Thread: Temperature gauge fluctuates
Results 1 to 15 of 15
  1. #1 Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    The temperature gauge in my 99 grand prix gt rises at idle, but never past 210 and then goes back down to while driving. I had a leaking radiator ane replaced it as well as both radiator hoses, thermostat, and cooling temperature sensor. After replacing these parts it stays at 210 while driving but goes up just before the red zone. Does anyone have any ideas as to what the problem could be? Please help. Thank you in advance.
  2. #2 Re: Temperature gauge fluctuates
    St. Louis
    Sounds like air in the system. These cars seem to be sensitive to it.
    Did you properly bleed the cooling system after replacing all those parts?
  3. #3 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    I bled it as best as I could, but I guess not good enough. I think I will buy a radiator funnel ans try to bleed it that way. Thanks for the help.
  4. #4 Re: Temperature gauge fluctuates
  5. #5 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    Bled out the system and it still does the same thing. I don't know what else to do.
  6. #6 Re: Temperature gauge fluctuates
    maybe a new radiator cap?
  7. #7 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    forgot to say that I replaced the cap also...
  8. #8 Re: Temperature gauge fluctuates
    Charles City, IA
    try bleeding it some more some times they are a *****.
    SMGPFC Two Nipple General
  9. #9 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    Will continue to bleed the system and see what happens
  10. #10 Re: Temperature gauge fluctuates
    New Jersey
    I don't understand your description.
    I'm guessing it stays around 210F cruising down the road, but creeps up while idling and sitting still?
    I would look into the fans if thats the case and forget bleeding. The fans should be running long before the red zone.
  11. #11 Re: Temperature gauge fluctuates
    I have seen a couple issues in bleeding one or two cars. This can happen when an air bubble ends up in the million dollar location. Then it's a pain to bleed.
    Best thing I've found is to pull the thermostat housing and thermostat back out. Fill to the top of the LIM if it isn't. Typically that's where I find the air bubble. Toss the stat back in and top it off.
    That's what typically works. Best of luck..I once fought for 2 weeks.
    Jack the front of the car up.. run it a little. change the T stat and refill through the hole was the best so far.
  12. #12 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    mr. tube your description is correct. the system seems to be working fine, i'm just having problems with the temp gauge
  13. #13 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    I finally found the problem. I had another leak, the heater hose fitting was leaking. I am set to change both of them on Wedenesday, hopefully this solves it for good!
  14. #14 Re: Temperature gauge fluctuates
    New Jersey
    Quote Originally Posted by wagatlng View Post
    This is where a pressure tester comes in handy, especially on an empty system filled with air
    Air = far more likely to leak, and hiss.
  15. #15 Re: Temperature gauge fluctuates
    Nov 2010
    chesapeake, va
    I replace the elbows and that seems to have done the trick. I'll keep my fingers crossed that I have finally solved the problem. Thanks to all who have responded to my post.
  1. Temperature Question?
    By nitecruzr in forum General Tech Discussion
    Last Post: 10-09-2010, 12:34 PM
  2. High temperature
    By Haulero in forum General Tech Discussion
    Last Post: 08-15-2010, 05:49 PM
  3. Erratic Temperature Gauge..HELP PLEASE!
    By gtpgrl2000 in forum General Tech Discussion
    Last Post: 08-12-2010, 05:50 PM
  4. DIC Voltmeter fluctuates between 14.5v and 12.6v
    By unclediesel in forum General Tech Discussion
    Last Post: 08-05-2010, 09:29 PM
  5. Is the temperature gauge accurate?
    By Summit670 in forum General Tech Discussion
    Last Post: 12-22-2008, 12:07 AM
